inside out turning
inside out turning
inside out turning
>Here is one of my latest turnings. It is a test piece for something really cool I have in mind. I needed to see what dimensions I have to work with on the final piece. This is Hickory, the vessel is 9" tall 5" wide with the finial about 12" tall. The finial is Padauk. Finish is lacquer.
I'll be demonstrating inside-out turning in Chattanooga tomorrow. I'll be doing a christmas ornament for them but the technique is the same.
From a critique standpoint I'm not sure I like the finial. This is the second finial I made and it still feels awkward to me. Somehow it just doesn't flow from the vessel to the finial.
The vesssel is pretty good but I wanted to make the bottom a little smaller. I couldn't because it was starting to cause problems with the openings in the sides. Any narrower and the bottom of the opening would have flattened out.
I did get to play with the John Jordan shear scraper. I have never been able to use a scraper very well on this type of vessel because it tears out the side grain wood on the leading edge of each opening. John's scraper did really well here as long as I did very light cuts. I'm really impressed with this tool.
Re: inside out turning
Photo information
>This was shot on Thunder gray sealess paper. I backlit the piece to make the paper go almost white and then carefully shaded the lights to make the backgound go black. I used a 1 by 2 foot strip light on the right up fairly high and 12" reflector light on the left slightly to the rear. The back light was a 6" reflector with a 20 degree grid.
It's nice to have access to this kind of lighting. You can still do something similar with quartz work lights. The hardest thing is grid light. This narrows the beam of the light so it doesn't light up everything in the room and also keeps the light out of the camera lens. You can do something similar by putting a homemade metal tube around your quartz light to narrow the beam.
Jerry Whitaker
>You do good work John and your photography is really something for all of us to strive for.
georgetroy
>This all good work John including the finial and I like that a lot. GT
Don Henthorn
>I like it John. Would the finial flow a little better if the base were just slightly rounded instead of stepped? Not sure.
>I wondered if it would flow better that way. I would like to make the base larger in diameter but no thicker but I didn't have any wood for that. It isn't glued in permanantly yet so I might try making something out of plain wood and dying it to see if I can solve the problems.
Keith Tompkins
Keith Tompkins
>Hi John, I think you are on to something here....I might suggest inverting the finial, making the finial appear as a long flame. The first thing I thought of when I saw this piece... rout a groove in each segment before glueing, and insert a pierced section in each one...just a thought. Nice!
>I'm ahead of you on this on Kieth. I already plan to do some inlay before and after turning but first I've got another idea to work on.
