Re: (OT) Any computer guru's out there?
Dinyar Chavda
>If you haven't solved your problem yet, I can receommend a series of steps that I would follow in your shoes:
First, I'd do what Bill recommended, i.e., "Try looking in Control Panel | Administrative Tools | Event Viewer. There are 3 event viewer logs I think. Look in each one and see if it gives some help"
What I would suggest is that after an event where your computer reboots, you go to each of these logs and see what, if any, messages occurred at the time when your system crashed. In particular, you are looking for any that are marked "error" or, failing that, "warning". If you find any, double-click on it, and it will show a description with a link. Try the link to see if it explains the problem adequately, else, google it.
If you do not find any such errors in any of the 3 logs, go down each one (or sort) till you come to error messages and see if there is any commonality amongst them.
If that does not help, try what Walt suggested re turning off automatic reboot (my XP system has these commands under control panel, systems, advanced, etc.. What may be happening is that there may be an error message at the time of the crash, and it is on the screen too briefly for you to see before Windows reboots, and making this change may allow you to note it, and then check it under the microsoft knowledge base.
If none of this works, post your problem in detail at http://forums.techguy.org/ . You will have to register (for free), and they will probably have you run hijack and post the log, but, with perseverance, you can often get an answer.
An alternative source that has been helpful is http://support.microsoft.com/newsgroups/ . The main problem here is deciding which forum to post under---in your case, your problem could go under WIndows, Internet, or hardware. Again, very knowledgeable, helpful people.
Finally, I'd go to the site of the hard drive manufacturer, and see if there is a forum there, or if there is a helpdesk that you can communicate with.
Hope this helps. From experience, I know that it can be a real pain to find exactly what the problem is, as the shin bone is connected to the thigh bone......
