We value your privacy.
>What do you guys use? I have a tiny walnut pot (the bottom is not smooth due to an unanticipated bullet track) and it is so dark that nothing shows up. I have a gold marker but the tip is not fine enough and I can't find an ultra fine one. Burning doesn't show either.
>LOL! This wood came from Colonial Williamsburg. I dug 4 bullets (22 cal) out of this piece. Here on the Eastern Shore, it's not unusual to find bullets or shot in wood...usually left by hunters or people target practicing rather than criminals, thank goodness!
Guess I am going to have to wait and get fine line metallic marker if I ever get to the city again. No sense in ordering one pen for $2 and paying $8 in shipping.
>Can you rechuck the piece into your lathe, opening toward headstock, (reverse chuck I guess it's called) and create a small circular recess to insert a lighter piece of wood with your initials or name?
I know that's more work, but it will help you spend the day today.
>That is what I have done before George, but this is almost black and so rough from the bullet track that burning a small sig is almost impossible. I think mmaybe my best bet is as others suggested and get a very fine gold or silver marker.
>Carol I find the dremel engraver works great on all my woods, dark or light. If I really want to highlight the signature I rub gold wax into the letters after engraving. You do have to finish the wood before you apply the wax or you will never get the wax off the non letter areas.
I use a Dremel engraver for my signature on all woods. Even if I don't use a gold or silver wax to highlight on darker wood, which I rarely do, it shows up just fine on the dark stuff. I'll bring it to Georgia so you can play around with it. I've tried everything and always come back to the Dremel.
I have a dremel but I can't seem to control the darn thing. Maybe I'll play around with it tonight and see if I can master it. WHere do you get gold wax?
>I bought a Gold wax stick from Cindy Drozda at the symposium last year. She uses it to fill all of her signatures. I'm not crazy about the look though... and if there are any open pores near your signature....it's flat out ugly if you get the wax in them....you have to keep it really sharp in order to put it where you want it.
>Carole do you have a dremel engraver. They are different than the dremel multi tools. I find with the engraver that I need a really light touch. Very little pressure. Let the tool do the work. I put the setting a little higher than mid range. I also found they work much better when the area you are engraving is sanded to at least 220 grit. If the wood has a big difference between summer and winter wood you need to be especially light with your writing pressure.
>The engraving bit is really hard to control. Those bits need to run at 50,000 rpm or faster to cut with any real control. The dremel only runs at 23k. They do work well for texturing which is what I use them for mostly..
