We value your privacy.
>Yesterday, I took possession of 5bf of 8/4 Gabon Ebony (at $70bf). The ends are sealed, but it feels like it is not dry. I will be slicing it lengthwise into 1.5" & 2" x 3/8" strips for segmented work. Anybody have a good idea how long I should let it set after cutting to dry?
Also considering putting it in a cabinet with a light bulb in it to act as a kiln.
>Mark: If you intend to put the timber in a cabinet with a heat source be sure to make the cabinet moisture tight so you can control the moisture in the cabinet to prevent the timber from drying too fast or getting "case hardened". Industrial kilns are very particular about slowly letting down the ambient moisture in the kiln.
>Mark, in my experience of using ebony for finial tops and bases on my hollow vessels, I do know that it does dry, because as they shrink, you can turn the finial 90 degrees, and it will become loose, 90 degrees the other way and they become tight. So, it does dry and it does shrink some, but to be honest, I agree with Ron, in that it takes a very long time for it to come to any reliable equilibrium if in any thickness at all. I have always just used dense woods like this as I got them, and have had very few worries, and no other problems as far as I know. Segmented work, though, it's a crap shoot IMHO. Make sure you are consistent, (no worries about that as far as I know, judging by the work we've seen from you in the past) and use good sense in orienting the grain, as you would in any other case.
