Segmented Bowl Software
Don Emmerling
>Hi folks,
I have been searching the internet for the software that prints out the dimensions of the wood and angles required to make segmented bowls. I have run across software that allows one to design bowls and things but not the segments like I am looking for. I believe the software that I am looking for also allows you to work with the segments to produce specific designs. Any help would be appreciated.
Thanks,
Don
Re: Segmented Bowl Software
Bob Way, Canton, MI
>Hi Don,
While you've likely found 5 or 6 software programs that will give the segment measurements, there are two in particular that allow a bit more flexibility with designing the bowls: Lloyd Johnson's Woodturner Pro and Bill Kandler's Segmented Project Planner. Segmented Project Planner has a routine that allows you to design feature rings and to paint your ring with the design element. The spreadsheet cut list will include the quantity, species, miter angles, and sizes needed to make the feature ring. Woodturner Pro doesn't necessarily have the feature ring design routine, but Lloyd has also produced a program entitled Lamination Pro that helps designing first, second, third generation laminates along the lines of Clarence Rannenfeld's book, and generating a material and cut list to make them. The designs from Lamination Pro cannot be copied into a Woodturner Pro project, but it's possible to use both programs in conjunction with each other to come up with a feature ring design and cut list.
With all that said, not all segmented turners use or feel a need to use a software program to design their bowls and feature rings. The math is really not all that tough, and often times graph paper and some colored pencils can help with the feature ring design. And that is oftentimes my preferred method. However, in spite of the fact I'm married to a wonderful woman and talented mathematics teacher, I do find myself relying on those three programs as a major aid at times.
Bob Way
Mark Kauder, Phenix City, AL
>I have used them all, and prefer Woodturner Pro. It has the easiest learning curve.
Full disclosure: I am an authorized reseller of Woodturner Pro. Email me if you are interested in buying it cheaper than you can get it from WoodturnerPro.
Mark
Re: Segmented Bowl Software *LINK*
georgetroy
>The others has listed some software programs for you. There is also a aoftware list in the latest AAW. You do not need a program to do segmented turning. All it takes is some graphic paper and/or your computer to make a drawing. With a drawing you can be exact and not have zig zags to fit inside a bunch of blocks. Measurements can be taken off the drawing and the projects can be turned inside out. This is what I learned from Curt Theobald. I also made drawings before the software programs came out 20 years ago. What set it off for me was the Fine WoodWorking magazine dated Sept/Oct. 1985. In that issue Bud Latven had an article on Segmented Turning which basely has not changed to this day. My basic instructions for segmenting is www.georgetroygraphics.com. Showing a simple drawing I made with Microsoft Graphic Designer which is free and in beta. All you do is sign up for it. I have other drawing programs and enjoy making my own designs. Listing the free Beta. GT
Graphic Designer
Keith Tompkins
Keith Tompkins
>Hi Don, If you are handy with basic geometry, a simple compass will give you all angles you need, and you can actually draw each segment exactly, set your table saw, and cut.It's That easy. For example a turning with six-segment rings will have 30 degrees per segment: 30x6=360 degrees. Set your jig to 15 degrees(two fifteen degree cuts equal 30 degrees per segment) make a test cut, and go for it.
By drawing each layer of segments with the compass, and dividing the circle into the appropriate number of segments, you can easily measure the length of each segment. Once you master the basics of this technique, the rest is easy. IN fact, you won't need the compass after a short while. You'll memorize the basic angles.
If you are attending Louisville, Linda Salter now demonstrates this same technique.
dick mc neill
>Do you sell lamination pro?
>Yes, by itself and in a Suite that has all three programs.
Email me if you need further information.
mkauder@ctvea.net or Mkauder@wcbradley.com
Mark
Keith Tompkins
Re: 30x6=360 degrees?????
Keith Tompkins
>A major oops! Should be sixty degrees divided by 2 would be 30 degrees.....the former would give twelve segments. Sorry!
RussFairfield
>This is the new math. It avoids leatning the Multiplication Tables for 12.
Its the same as rounding Pi to 3 to make calculations easier.
Keith Tompkins
Keith Tompkins
>Russ, you will never let me live this one down!lol!
