Supernova2 Chuck
Supernova2 Chuck
Supernova2 Chuck
Donald Johnson
>Need help with my Supernova2 Chuck. Got a new lathe, new insert and the chuck wobbles! Does anyone have a phone number for Tim Guist at a Nova Service Center in West Virginia. I also might add that I had a Jet 1440 lathe with this chuck, replace the inserts twice. The second insert worked better than the original, but it still wobbled. I gave up and decided that the Jet lathe was the problem, it never really ran smooth. The new lathe Powermatic 3520B, runs very smooth, the face plate runs smooth, turning spindles between centers is a dream, but the original chuck still wobbles. I took the jaws off, cleaned everything, put it back together with no help. Thanks in advance for your help--Donj
Re: Supernova2 Chuck
Tim Barker
>I had the same problem with the PM3520A and received the solution here.
The problem is that the insert/chuck isn't seating all the way on to the spindle. The PM lathes have too many threads causing the the front of the spindle to bottom out in the chuck. You can get a precision washer to space the chuck out so that the insert/chuck hits the washer and the washer hits the spindle before the spindle threads bottom out.
I made my first spacer out of UHMW plastic but I don't recommend that for a long term solution.
I hope this helps you. Also, I'm suprised more people haven't mentioned having the same problem.
Tim
John Dillbeck
>Call PM and they will send you a machined washer about 3/8inch thick. ait allows the insert to seat on the washer rather than the spindle threads.
