Have a question? Ask Woody!
Alternate to coffee grounds
Bill Hale
>It seems that most think coffee grounds is the best filler, but.
Whenever I am turning wood of any special color eg. ironwood or purple heart I clean the floor prior to the turning and then save the chips. Put the chips in a coffee grinder and make a colored filler. You can grind course to very fine. I save in Kerr canning jars for future use. I also grind my rock fill the same way.
Good turning and be safe
Bill in Casa Grande, AZ.
Re: Alternate to coffee grounds
Steve in NC
>Good idea. Do you use a regular (Push down the lid and it grinds with two blades) grinder. Seems like it would be under powered for grinding wood chips. Don't want to try it and then have to return damaged grinder to the cupboard.
albertabob
>Why don't you just sand some of your stock and save it?
Bob
Jim Barbour
Jim Barbour
>I use an old two-blade grinder and it works fine. I don't put in big pieces, but turning shavings are fine. I also don't do a lot, but it has lasted for two years, after reaching the end of its useful life in the kitchen (my wife got a newer, fancier model ...).
Keith Tompkins
Keith Tompkins
>ground bark works well also...
