Wood for end-grain turnings
Bill Howatt
>In my never-ending search for something I am good at, I am starting to try some end-grain turnings. I have made a couple of goblets out of dry maple and I've done some christmas ornaments out of dry spruce (old Christmas tree).
I have some maple and other free wood in my storage but it is in various stages of dryness.
Should I wait a long time until they are dry and then turn them?
Can I do the rough turn to 10% of diameter, dry, finish-turn, trick like I do on my bowls?
How dry should they be if I just want to do a one-time finish turn?
Any other advice?
Thanks,
Bill
Re: Wood for end-grain turnings
Wally Dickerman in Arizona
>You can do all of the above. Left alone, they will take a long time to dry, if ever. You can rough turn them, but with end-grain you can turn them to a lot less than 10%. Warping out of round with end-grain, especially if it's semi-dry, will be minimal. Do protect the wood with a sealer. I use a generous coating of Johnson's paste wax. You can also turn them to a finished thickness while they are still wet. Just be sure to have the wall thickness nearly the same throughout to prevent cracking.
Wally
georgetroy
>Wally has the right of it Bill. Wet turning of end grain is fun. It gives you a chance to use some small limbs. I had one of my apple trees split off. I went down yesterday and cut some turning stock. All from 3-4" in diameter. These little guys make great vases and goblets. Go forth it don't wait. I use super glue to reinforce tenions and lacquer inside & out to reduce cracking. Knots are a bonus just keep them super glued. GT
>Bill e-mail me and I will explain how I turn christmas ornaments from green wood.
Vases
Bill Howatt
>George,
If you hold your vase in a chuck, approximately how long can the vase blank be to end-grain turn it without a steady? I'm thinking of a blank around the 3-4" diameter range. My chuck is a Oneway Stronghold.
Thanks,
Bill
Thanks everybody, very helpful!!!
Bill Howatt
Brad Vietje
Re: Vases
Brad Vietje
>Bill, I'll jump in here for George, but he may have a different answer...
I'd say it really depends on the jaws you use, how well you prepare the blank between centers for those jaws (getting the size and shape correct), and the character of the wood in question. Some limb wood or small diameter tree trunk sections are very slippery, especially spring-cut wood, and when working near the diameter of the bark/cambium layers, they can tend to be pretty juicy (slippery). Some people actually glue the jaws to the wood with CA (sticks to damp wood), and I'd imagine they scrape this off after heating it -- CA gives up when heated -- but I have not resorted to this.
In my experience, you're better off with a smaller diameter, well-shaped tenon that is well below the bark and/or cambium than going for the maximum size you can chuck.
Safe Spinning,
Brad Vietje
Newbury, VT
