200+ woodworking book reviews
First shot a goblet
First shot a goblet
First shot a goblet
Norm
>This was a gift for a friend at work, didn't know hollowing the end grain would be so hard, let me know what you think, Box Edler is a joy to turn! Thanks Norm.
Re: First shot a goblet
Really Nice!!
Ron in Drums PA
Norm Smith in Nova Scotia
>Norm,
You did a great job on this piece. Can`t ger box elder in this part of the country.
Norm
>Real attractive. Like the stem and the transition into the bowl portion a lot. I'd like a bigger bowl - if it was going to hold something that is ;).
Thanks!
Norm
>Thank you!! Yes the bowl started much bigger, but an small oops fixed that, has well it was supposed to have a captive ring, another oops finished that idea! oh well all the more reason to try again.
Keith Tompkins
Keith Tompkins
>Nice job, Norm! Especially for the first time.
there is an easier way to turn end-grain pieces....using a detail gouge with a swept back grind, start at the center of the "bowl" portion with the flute facing you. (cut with the lower edge) Make a small divot, about 3/8" deep. Then , pull the tool toward you; I simply curl my hand tighter to do this. NOW you are cutting side grain! Make another 3/8" deep cut in the center, then scoop out toward the rim. That way, the only end grain you are removing in in the center with ;the initial cut.. Keep the cutting edge just above center, this will help avoid big catches. The tool can be moved with an in and out motion to clean up any bumps.
Norm
>Thanks keith! I'll have to give it a try, would it help if i drilled a pilot hole first? Thanks!
Keith Tompkins
Keith Tompkins
>Maybe Norm , but no need!
