Re: Revolving Center:Need advice
Phil Joines Krum, Texas
>It depends on what you turn. A live cup center with a removable point will do most things.
If I'm turning largish spindles or bowls I use the center with the point.
For long, thin stuff (1/4" thick and smaller) I like the type where the revolving part is just the center rather than the outside because it reduces rotating mass. This can be important if you need to stop and restart the lathe.
If I'm turning a long, thin spindle I want to be able to remove the point that most cup centers have. That lets me put the finished end of the spindle into the cup without damaging the end.
If I'm turning a goblet with a thin stem I want to be able to add a piece that will go into the finished cup of the goblet to hold it steady while the stem is turned. The piece could be metal like the Oneway if it's padded with paper towel. I prefer to make a centering piece of wood that is as light as possible to reduce stress on the spindle.
If I'm turning pens I need the point to hold the end of the mandrel.
If I'm turning metal I usually use a 60 degree machinist's center.
