Another Coffee Grounds/Filler Question
Tom Minehan
>At what stage of the process are the grounds/fillers introduced - rough turning, final turning, sanding or as a final step?
Re: Another Coffee Grounds/Filler Question
Carole Valentine
>I usually put them in just before the final finish cuts.
georgetroy
>Seal all surfaces after sanding before you use Super glue and grounds otherwise you may have staining and blotching. Deft clear wood finish works great for sealer. I also use a sanding sealer in leau of. GT
Leo Van Der Loo
Leo Van Der Loo
>Hi Tom
I fill after rough turning, any spills or stains are turned away when finish turning, also gives added strength to the area to minimize splitting, and the wet wood does not soak up as much and deep the CA as dry wood.
Have fun and take care
Leo Van Der Loo
Thanks to All
Tom Minehan
Carole Valentine
>That's why I prefer to use epoxy...it does not get wicked down deep into the wood, especially punky wood.
