Power carver help
Power carver help
Power carver help
Ed Moore
>My new Wecheer power carver arrived yesterday. I have been told by a carver friend to lubricate the power shaft frequently. I looked at the instructions that came with the carver and under lubrication it said simply not to add grease to the power shaft.
So, my question is simple: What lubrication regimen should I follow?
Thanks,
Ed
Re: Power carver help
>Ed I bought mine at the flea mkt and not instructions came with it. I've been lubricating the shaft with White lithium grease. I apply a thin layer and then wipe it down with a paper towel so there is very little left. That has seemed to work for me.
Ed Moore
>John,
Do you separate the sheath and the shaft and apply the grease? How often?
Please note, I have not even taken a good look at this unit yet. I have some white lithium grease.
Thanks,
Ed
>Ed I'm sure I don't do it as often as they say. I've had my old flex shaft for 4 years and probably lubed the shaft 4 or 5 times. The Weecher I've only had for 6 months and only lubed it the day I got it. I've done a fair amount of work with both.
I pull the cable out of the sheath. On my units it's very easy to do.
Ed Moore
>John,
On a whim I wrote to the supplier and got an immediate response. He said that the manufacturer recommends no lubrication.
Hmmmm! I can understand that one should not over-lubricate, but NONE?
Maybe I should buy a spare now. ;^D
Thanks,
Ed
Andy_B
>Ed: I've used mine for about 4 yrs. Never lubricated it and it has not broken yet.
Ed Moore
>Thanks, Andy. Is it a Wecheer?
Ed
>Ed I also have a flex shaft for my dremel. I think I still have the instructions for that. I'll look and see what it says. I would say too much of the wrong type of lubricant would be as bad as having the cable dry out. It all puts strain on the motor and the cable connections.
Andy_B
>Sure is Ed.
Thank you Andy B and John!
Ed Moore
