Veritas - Innovation in Tools
Segmented Hollow Form *Pic*
Ron in Drums PA
Curly Maple, Maple Burl and Bubinga
Stands about 5-1/2" tall
Comments Welcome and Thanks for Looking.
Re: Segmented Hollow Form *Pic*
ad de Crom
>Hi Ron.
You did a great job, very nice form, very well executed collar.
I like it a lot.
Ad from Holland
Very Nice
>Beautiful piece there Ron. Nice form and the lines enhance the shape. Very cool.
Tommy
Mac
>Ron, That is a very classy piece, I like it just as is. If you make another one sometime in the future,consider making an inserted rim from the same material that the band is made from. Dont know if this would look good or not,just a thought....
Carole Valentine
>Beautiful Ron. I like it's simple elegance. I think Mac might have a good idea about the rim.
Ron in Drums PA
>That's an interesting idea Mac, I'm going to give it a try. Thanks
Re: Segmented Hollow Form-attaboy
georgetroy
>Hello Ron,
This is your second attaboy from me, I gave you one on WOW. Nice work!
I would hope you are making duplicates that you can set aside, this is what I do once I get a setup dialed in. I have the luxury of two saws. I use the table saw for flat segments and use my miter saw for compound cuts. From there I can make runs or ruins(lol). I enjoy your work kept it up. GT
VERY WELL DONE
Bernie
I did!
Ron in Drums PA
>After I knew I had the first layer right, I decided to cut a second set. So I'm guessing this is a something everybody does, and here I thought I had a new idea.
Carol took the words...
Rob Ceraso
>...right out of my mouth. Simple and elegant was exactly what I thought when I saw it.
Did you use compound cuts or just thick wood?
Very very nice!
Rob
Re: Carol took the words...
Ron in Drums PA
>Thanks Rob
These are compound mitered joints.
Beautiful
tek-Brunswick, Ohio
>I don't do much segmented turning. A poor segmented turning looks about as bad as it gets. They really take a lot of good planning. The segments need to follow what the curves should be. I see to many pieces where the curves are forced to follow the segment rings and the curves are not pleasing. This turning is really top notch. You may have inspired me to try a piece similar to yours.
Tom
Rob Ceraso
>Thanks Ron - would you mind sharing the angles? That's a form I'd love to add to my bag of tricks.
Also, the alignment looks perfect - how about a pic of the bottom?
Fantastic Job and I like the rim
Craig Daymon
>Absolutely wonderful. I like the rim just the way it is. The lines of the segmentation draw you (me) up to the rim and right down in. A solid color collar would stop that. The way it is now, I follow the lines up to the rim and want to look right inside and see every inch of it.
The raised lip you created creates quite enough transition to define the top of the vessel without taking away from what I described above.
-Craig
Leo Van Der Loo
That is a Beauty Ron.
Leo Van Der Loo
Randy Gleck
>Great looking piece Ron, Very nice looking. I would like to see that Rim done Like Mac suggested as well. Could be interesting.
Randy
Keith Tompkins
Keith Tompkins
>Hi Ron, this is a beautifully done piece....it would work both ways, as is, or with a matching rim and ring.
My only caution would be to watch grain direction....what may seem to be glue creep may actually be the wood segments working against each other over time....I can't be sure, but there appears to be end grain glued to side grain.
The form flows nicely...good to look at!
Very Beautiful
Dick Parr
Thanks Everyone!!
Ron in Drums PA
