Re: Question for Jennifer *LINK*
Rick Allen
>Hi Dennis
The colors can only be as vibrant as the background will permit. White wood like holly or bleached wood provides the best background for bright vivid colors. I have used Prisma Color on pine and the results were vivid.
Prisma Color markers are alcohol based. If you put a finish over the color it will likely dissolve the color. If you are careful the dissolved color will stay in place. Also Prisma Color isn't very light fast. These colors will fade with exposure to light (all colors will fade with exposure to light, just that Prisma Color fades faster than some other products).
Instead of Prisma Color...
There are water based colors but these require that you raise the grain a few times before coloring. There are reactive dyes which react with natural materials like cotton, wool, wood. These dyes tend to be very light fast. Because these dyes can be delivered with water instead of a solvent like alcohol you can apply solvent based finishes over them and expect the color to say in place. Many of the finishes we use darken the wood. Those finishes will also darken dyes as they are primarily a coating that is dark. Select a finish that is gin clear and this will not be an issue (as long as it isn't water based which will of course dissolve the dye).
I have purchased from Pro Chemical and found the product to be as expected. There are MANY other sources for these dyes. MX Reactive dyes is the product I have used. Mix with water and apply with a small watercolor paint brush. The minimum quantity is 2 OZ. You can buy "kits" which have smaller sized samples. That is a LOT of dye. Enough to make a quart or more of dye. I mix with a toothpick. The amount of dye I can scoop out with a toothpick, two or three times mixed with a soda bottle cap full of water will provide enough dye to color 5 or 10 square inches of wood.
It is always a good idea to try the coloring and finishing out on cutoffs so you have a better idea of what to expect.
Good Luck
Richard
MX Reactive Dyes at Pro Chemical
