We value your privacy.
>I have seen several posts where coffe grounds are used as filler. Can someone tell me how this works. Do you use dry grounds. What is the filler, CA? Epoxy? Does it matter Decaf or regular (LOL)_
>Then I dry the grounds in the microwave, using a 20% power setting. I keep them in a zip lock bag until I need them. To reuse, I pack the flaw with the dry grounds and drizzle in thin CA glue.
>Steve, it works well with either epoxy or CA glue. The resul is sort of like a bark inclusion if the coffee is coarse or like knot wood if it is grownd to a fine powder. I have been known to splurge and use fresh coffee rather than recycled grounds. :)
>New, used, doesn't matter. I use CA because it's always handy, available and easy. No mixing, no waiting, just squirt it with dryer and you are ready to go. If it is a big opening I pack in the grounds, ca, more grounds, more ca until I fill it slightly above the level of wood. Works great.
>Steve, I dry my grounds overnight in a warm oven -- spread out in a pan or on a cookie sheet. Even so, in the humid summer, it is possible for them to mold, so I toss in a silica gel pack to keep the moisture level down. I like a coarse grind -- looks a bit like a bark inclusion. You can use a mix of coarse and fine grind to make it look even more realistic. Have fun experimenting. ...Gary
I have used coffee grounds also but now I mostly use sawdust with epoxy. I have a tube of Artisan water mixable oil colour paint in dark brown. I mix the sawdust (however course I want) with epoxy and than add a bit of the paint. I can colour the mix to whatever shade of brown that I want, depending on what I want to fill. It works great.
>I use some old espresso we have and grind it even finer with a yard-sale coffe grinder. I layer the coffee so the thin CA penetrates well. I often use the DC to draw the fumes away. You might even see it smokin'.
Sometimes, by mixing some brass key filings (also ground very fine) with the coffee, you can achieve an interesting range of effects.
>Thank you all for your suggestions. I had no idea coffe was used so often. I have a ambrosia maple bowl rough turned that will be my first test case. I will post the results.
