re: ebonizing wood
Matthew fallon(long island ny)
>Heya ed' this ones really nice. i like the one you had at the last meeting. sure nice to be able to see your artwork close up and in person ;)
(we're in the same clubs,heh)
Ed i wanted to tell you an even faster trick i learned for this ebonizing method(just for making the rust part) what you really want to do is dunk the steel wool then squeeeze out the vinegar and let the wool sit outside in the air where it'll get more oxygen,this is what causes the reaction, you'll literally see and feel(it gets very warm!) the rust setting over the wood. i bet a fan in front of it would help even more ;)
after about 5 minutes i dunked it in and all the rust came off into the vinegar, i then repeated that about 6 times then got bored and jsu tleft it in... im trying it out on some ash,pecan,apple and african mahogany. the first coat 2 days ago made a nice even grey on all but the mahogany(i couldnt really tell much on it) especially the ash.. i added another thick coat last night and will chek it again today...
some other methods i've come across was using hydrogen peroxide instead(i believe both of these are just in order to dissolve the protective coating on the wool?) another was to use a dc converter like for a train-set and wrap the positive lead around teh wool/nails, and leave it overnight... i guess whatever method makes the most iron oxide the fastest would be the best way....
any other formulas for ebonizing out there?
