We value your privacy.
>I need a little help with a Sorby chatter tool. I bought this tool used and I�m not exactly sure how to use it. It has a tool handle with a blade that can be adjusted in and out. The flat blade has a square end and a pointed end, appears to be sharpened.
I tried to use it on the rim of a bowl with horrible results; it just tore up the wood. I�m not sure how to present the tool to the wood, at what angle, speed, how it should be sharpened it, and how far it should stick out. Can anyone give some advice?
>Ben The chatter tool only really works on end grain. It tears up long grain pieces. It does take some practice. Put short piece of scrap in the lathe with the grain running parallel to the bed. Us a chuck or faceplate to hold it. Clean up the end. Now place the tool on the tool rest so the thick part of the metal is on the tool rest and the chatter part is hanging out. rotate the tool CCW until the cutter is at about 7 oclock and is a little lower than the handle. Now push the tool in. It should produce some chatter.
You have to play with lathe speed, where you are in relation to the center(which is also surface speed) and how hard you push. Once you get a feel for this try rotating the tool CW or CCW to see the difference in the cut. Then try the round end of the cutter and see the difference.
It will take quite a few tries to get comfortable with this tool. I like to make chatter work discs that can be inserted in other turnings. I'll put a 6" piece in the lathe and make as many as I can. I chatter the end the then part it off about 1/8" thick, clean up the end and chatter another one.
>John's info is right on. I use the pointed cutter sharpened with a slight relief and the burr removed with a diamond hone or a piece of sandpaper. This should last a lifetime unless you do a great amount of chatter work. For the expert on chatter work look up a video by Bonnie Klein. Look for samples of her work and see what can be done. Side grain chatter work can be done on spindles holding the flat of the cutting edge against the wood. I also find that the higher speeds work best about 3000 rpm. Remember this speed is for small pieces such as boxes and spinning tops.
>Russ, That is a beautiful bunch of tops. We do a yearly Top-A-Thon for charity, and I would like to know what pens you use to color them with. The colors are nice and sharp with no bleeding. How do you do it?
>Per Bonnie Kleins suggestions. Use Tombow or Staedtler brand pens. They have a hard pointy end and the other end is a brush like point use the brush point and while the lathe is running runn the marker over the high points of the chatter. Point the pen in the direction of the lathe so you don't mash the point. We do these at the county fair and the kids love them. I also give them away to the ladies at our Christmas party, another big hit.
We also do the tops at the county fairs and at the wood shows in the area. Big hit with the kids, but we've had great response from adults too. Thanks again
