REAL MILK PAINT
1st Natural Edge Bowl-Oh well
Chris DiCiaccio
>Got my nerve up enough to try a NE bowl. Found a log on the wood pile with a little spalt to it, think its poplar, but works for practice. Didn't get to the 1/8th wall on this one. maybe next time.
Re: 1st Natural Edge Bowl-Oh well
Chris DiCiaccio
Chris DiCiaccio
Chris DiCiaccio
Chris DiCiaccio
Carole Valentine
>Good first effort, Chris. The first NE is always a little scary. Are you going to reverse it and cleanup the base?
Rick Davenport
>Nice piece Chris.
1/8" may be asking too much of the bark, it would probably fly away.
Rick
Well Carole,
Chris DiCiaccio
>That's a good question. I don't have a revolving cone center yet, only a cup center which makes it kinda tight. I have a oneway talon jumbo jaws but don't know how to use it to hold this uneven edge. How can I hold it to finish the foot? Still learning, thanks for any advice.
Re: Well Carole,
Rick Davenport
>Jam chuck.
Others can explain it way better than me.
Or you can refer to it in any number of books.
Rick
Re: Well Carole,
George Van in WI
>Hi Chris, nice job for your first NE bowl. You can chuck a piece of PVC pipe in the jaws of your Talon and place a mouse pad, carpet pad scrap or ��. I true the end of the PVC pipe; a block of branch or any wood will work for a jam chuck also. Put the bowl over the pipe/pad and bring up the tailstock, adjust to get the bowl running true. Then remove the tenon down to a pip where the tailstock remains. Then remove the bowl and cut the pip off with a sharp chisel. Do not cut entirely flush or you risk the chance of marking the bottom, finish by sanding smooth.
Jamb Chuck
>You could put a block of scrap wood in your Talon Chuck and turn a ring or a dome that fits inside your bowl. Doesn't have to be full size, maybe three or four inch across. I try to make them touch the bottom of the bowl and touch at the rim of the block. Then I put a piece of the old carpet pad that is foam over the dome and press the bowl over than and bring up the tail stock. The tail stock "jambs" it home, Thus the name. The carpet pad provide friction for the scrap to drive the bowl and prevents or reduces marring the inside of your bowl. If the base is thick enough you can just drive whatever center you have into it, if not you can glue on a little piece of scrap to prevent the tailstock center marring the bottom. The original hole that appears to be in the bottom of he bowl makes centering it easy or you can fiddle around until you get it like you want it.
Turn and sand the bottom, leaving a little nub in the middle for the live center. Once you are finished on the lathe, you can pair the nub off with a small saw or a sharp chisel and then sand the spot.
The reason I like the jamb chuck to touch the bottom and the sides is that if it only touches the sides, you take a risk you will burst the bowl or punch the live center through the bottom. It is touches the bottom of the bowl, you can apply considerable without doing harm. I am more comfortable with fairly large jamb chucks, but they can really be quite small. Don't throw it away. I have one I have been using for years. Just put it back in the chuck and true it up for next time. I put a mark on it lining up with the number 1 on my chuck jaw so I can put it back in the same position every time.
I use the cheap carpet pad, not the kind made of crumbles of foam. you could use anything like neoprene or chamois, maybe even paper towels.
One of the "tricks" on NE bowls is to keep the wall thickness exactly the same from the high wings down into the bowl, past the low points. Looks like you did a good job. It really shows if you don't.
Re: Well Carole,
Carole Valentine
>I think you got the idea from the responses. I have a whole box full of various sized jam chucks. I pad them with pieces of adhesive "foamies" (here we go again - what are foamies?) from Walmart. Foamies are sheets of closed cell foam material about 1/8" thick with an adhesive backing available in the craft department. They provide a decent amount of friction to drive the piece as well as protecting it.
PS
Carole Valentine
>I use an oval carbide cutter in my dremel to make quick work of the nub that is left. Much easier than trying to chisel it off, IMHO.
To all of you:
Chris DiCiaccio
>Thanks for the help. I will try these methods on the jamb chuck. I have a piece of non slip router pad that might work on the jamb once I make it. The foot on that bowl is about 1/4 x 1 1/2. When I bring up my tail center (cup center which is about 1/2) it looks like I am not going to be able to turn but a portion, still leaving a 1/2' to 5/8" where the cup center was. I guess I can handle that with the dremel or chisel. Is this where I need a 60deg live center? I assume I am aiming for a concave foot, right? Thanks for helping this beginner, my lack of knowledge is showing, but regardless, I am learning.
Re: To all of you:
George Van in WI
>Chris, that 1/2 inch pip will be gone very quickly with a chisel and sandpaper. Many times i take out the tailstock center point and just use the outside circle when i am concerned with a thin base or worried about the point crushing fibers below the area I want to finish for the foot. Once they are crushed I can always see them after I sand. This is not a problem if my tenon is thick as yours appears.
Chris....
W.C. Turner
>I also use a plastic cap, similiar to one that comes off a drink bottle, to go over the end of the live center. It's better to remove the live ctr. point first, for better protection.
Leo Van Der Loo
Re: To all of you+1000 words,as they say *LINK*
Leo Van Der Loo
>A picture is worth a thousand words, this saves on finger and keyboard wear.
Lots of good advise already, here's some more, self explanatory I think, the little cut off ends have a centre mark already and sit stable, give you more room and do no damage to your tools if accidentally touched, the rubber balls conform to shapes even when drying has made them warped.
Have fun and take care
Leo Van Der Loo
http://homepage.mac.com/l.vanderloo/PhotoAlbum4.html
