Griz chuck *LINK*
Griz chuck *LINK*
Griz chuck *LINK*
Phil Joines Krum,Tx
>I got a chance to check out the Grizzly "Lathe Chuck" this weekend. I can't see any differance between it and the Vicmark. It's well made. The Griz is $100. I don't recall the exact cost of the Vic but it's a good bit higher. The chucks don't use an adapter for the spindle but are available from 3/4-16 to 1 1/2-8 but not in 33mm. The included jaws hold an aproximatly 2" tennon. There are two accessory jaws, 1" pin and 4" dovetail. They are $18.95.
Since I have 4 Super Novas I was mostly interested in the jaws. They will interchange with the Super Nova and I beleave the original Oneway. The Griz pin jaws have a center opening of about 1/8". The Nova pin jaws won't hold anything smaller than 3/8" and I need to turn small diameter things fairly often. I'll be ordering a set of them today.
I understand from my friend that Griz sells replacement jaw screws at a good price but I already have extras.
Lathe Chuck
Re: Griz chuck *LINK*
Re: Griz chuck
>Phil If you are looking at the one that looks like the vicmarc chuck, I have one. It is a good chuck. They do have inserts that are replaceable but you order it with the one you want.
I don't believe the jaws are interchangeable with any other chuck. Possibly the Nova, I haven't seen one of those but I know they won't enterchange between the oneway.
You can swap out parts on the vicmarc. I also have vicmarc chucks and have swapped the jaws and inserts to see.
Re: Griz chuck
George Van in WI
>I got one Phil when John and others were talking about them. Mine was .033 out of round at the jaws. The good thing is Grizzly said that was unacceptable and asked me to return it for exchange or refund and they would refund my shipping charge. I am waiting for the replacement this week as they were out of stock and waiting for a new shipment from China.
Re: Griz chuck
Vicmarc.fan
>I admit up front I am mad at Grizzley for not refunding my postage on an out of round chuck when they first came out. I sure didn't need a mike to measure it, it was so far off you could see it but Grizzley claimed it was fine and you have no choice in the matter. My question is if you own a Vicmarc chuck why buy a piece of junk from Grizzley? Could something made in China be machined better than one machined in Australia?
Ron
Well --- Yes.
Eddie Pacheco, San Jose, Ca.
>If a country can rage a war, and have a space program there's no reason they can't manufacture a good quality scroll chuck. The Numerical Control machine programming language knows no boundaries.
I purchased the clone jaws from Griz. for my Vicmarc and they were indeed a little better made than jaws I've received from Vicmarc. The sharp edges were all broken on the Griz. jaws while I had to deburr the edges on the Vics. The jaw number is laser inscribed on the Griz. and are had stamped on the Vics. The overall machining on the clones looked a little better in that the feed rates of the machines weren't as rushed resuling in a nicer surface finish.
Don't get me wrong I like my Vicmarc chuck and I know they need to recover development & manufacuring costs along with making a suitable profit. I tried the Griz. jaws with trepidation, but they were good, real good.
Re: Griz chuck
RussFairfield
>I have revised my article on chucks to include these new opperings from Grizzly, PSI, and Craft Supplies. The following is what I said about them. You can read the entire article on my Website by using the link.
NEW CHUCKS FROM PSI (Baraccuda, etc.), GRIZZLY, and CRAFT SUPPLIES (Artisan).
There are several new inexpensive chucks available on the market. While each supplier will argue the merits of their product, they all look the same to me, and like a copy of a Vicmarc chuck. All appear to be a good buy for the beginning and average hobbiest woodturner because they come with several jaw sets for about $160, or for about $100 with a single set of jaws. The PSI chucks are the only ones I can comment on because they are the only ones I have had a chance to closely inspect and use.
Don't expect to get the same steel as the other chucks at these prices. Testing them with a file tells me that the steel is probably a common low carbon "Mild Steel", rather than an alloy steel as used in the more expensive chucks. That means they are made from a softer steel, and that they will wear out quicker. A high volume woodturner would be better off spending the extra money for a better quality chuck. The hobbiest woodturner will never know the difference.
My only adverse comment about the PSI chucks is that the jaws on the ones I used were at a "true circle" when fully closed. That means that the grip will always be at the points of the jaws for all sizes of spigot, and always in the center of the jaw for a recess. That means I could never use the light but firm grip where the jaws and the sligot (or recess) were at the same diameter. I would suspect that the average woodturner would never know the difference.
Other than that, they appear to be well made, and the machined fits were good. The PSI version had a black coating that appears to something other than paint. If the coating is similar to that used by Nova and Oneway, rust should be less of a problem.
I have been told that the Vicmarc chuck jaws will fit the Grizzly, but I have no personal confirmation of that. I will revise these comments to reflect interchangeability when I know something for certain rather than relying on rumors.
Re: Well --- Yes.
>Eddie I don't think my clone is quite as good as my Vicmarc but it has worked perfectly and was $139 less expensive.
Re: Griz chuck
>Russ I have both vicmarc and Grizzly and the jaws and inserts are all interchangeable. I have 4 different sets of jaws and 4 different inserts. I tried them all swapping things back and forth and they all fit. The fit and finish of the Grizzly isn't quite as clean as the vicmarc and there's more slop or backlash in the jaws but I've used the Grizzly extensively next the vicmarcs and don't see any difference in actual usage.
Re: Griz chuck
Jerry Whitaker
>I am mad at Grizzly too. I ordered a chuck from them and the chuck body had two large voids in them. I returned it for a refund but the refused to refund the postage both ways. You sure gotta watch what you buy from these guys.
Re: Griz chuck
bob davis
>very interesting..does anyone know for sure that the griz jaws fit the nova ? i sure would like a jaw that clamps 1/8"
Jaw interchangability
Phil Joines Krum,Tx
>The screw hole locations on the Griz, Vicmark and Super Nova are the same. The location and width of the boss on the back of the jaws is the same but on the Nova they are thicker. The Nova jaws won't fit on the others but the Griz and Vic jaws will fit the Super Nova slides. If I remember correctly the jaws for the Nova and Super Nova are interchangeable so the Vic and Griz jaws will fit either. Also, if I remember the jaws for one of the Oneway's will fit the Nova but I've never tried it.
I'd like to get a set of the O'Donnel or Batty jaws but not for $200.
Re: Jaw interchangability
bob davis
>nova jaws will fit oneway talon
