Grinding wheels (*&!@$%)
Carole Valentine
>Well, I did a stupid thing today and was just lucky I didn't get hurt. Went to sharpen a roughing gouge and for some reason did not tighten the Wolverine down tight. WHAM!!!! Ruined my 60 grit wheel. It didn't fly apart luckily, but it's got a big chip out of it. Sooo...now I am out of turning until I can get some new wheels. I am assuming that both wheels should be replaced for balance reasons? Are the Norton wheels worth the price? What a bummer.
Re: Grinding wheels (*&!@$%)
Don O.
>Wow, scary image that conjures up! Glad you were not hurt. Sorry but I can't help with stone quality though. Norton usually makes good products. I know you'll be more careful next time.
>Carole If the nick isn't too deep just use your whatever you true up the wheels with and grind down past the chip. If it's a big chip the wheel could be cracked and it might be dangerous. I wouldn't think you would have to replace both wheels. I didn't when I chipped mine, oops I wasn't supposed to admit that.
Bill Howatt
>No need to replace both wheels.
I did something similar; wasn't paying attention and my gouge went over the edge when using my Vari-grind jig. Took a small piece out of, and put a groove on the edge.
I took the wheel off and tapped it gently to see if it would "ring" rather than "clunk". A clunk means that the wheel is definitely cracked. Sorry, I can't describe it any better than that. It rang so I put it back on, stood well to one side, and ground a long piece of scrap steel on it (with my faceshield on). I then dressed the wheel.
That's what I did but some people will tell you not to take chances with the wheel and throw it out. An exploding wheel is no trivial matter but since my damage appeared fairly minor I did the above.
Bill
It rings
Carole Valentine
>But it's a mighty big chip out of the corner of the wheel so I think for my own piece of mind I will replace it. So I take it that it really doesn't matter if one wheel is down to 7 1/2" diameter and the new one is 8"? I was afraid maybe the difference in weight might cause vibration problems or something. Anyone use the Lee Valley white wheels? There are so many wheels out there it gets confusing. Can't afford the Norton 3x.
Re: It rings
Mac
>Carole, You dont have to throw that wheel away.It can be reshaped to any contour you want,such as a bead,cove etc. to grind custom shapes.You can shape it to do any odd shape you want to make on a scraper etc. Just use a diamond wheel dresser on it.
Re: It rings
Brian Hahn in SW Wisconsin
>The only thing that matters is that each wheel is round and relatively balanced. A "lopsided" grinder works just fine. One of my grinders only has a wheel on the left side. The right side is empty because I bent the shaft with a really nasty catch. :-((
Re: It rings
Bill Howatt
>Right now, one wheel on my 6" grinder is close to 6" and the other is about 4.5". I have a new wheel to replace the small one but I can't find where I put it. That seems to happen a lot these days :) !
Re: It rings
Ken
>I've been using norton stuff for years and no complaints.Just stay away from that harbor freight junk and that stuff you find at those flea markets for 5 bucks as they ARE junk.You can buy great wheels at woodcraft for 20 bucks.They are well balanced and with proper care will last a long time.
Ken
Re: It rings
Carole Valentine
>Hmmm...I will keep it and *maybe* do that. Now that I have gotten over my fright, it doesn't look as bad as I originally thought. I can't hardly imagine anything more frightening than having a grinding wheel disintegrate though. Maybe I will throw it in the car and take it to GA for some expert opinions!
Thanks folks
Carole Valentine
>That "little voice" was talking to me, so I listened and ordered a new wheel. For the $$ it's not worth cringing every time I turn my grinder on. And certainly not worth the possible ER expense should that chipped wheel fly apart on me.
Re: It rings
Barry Turner
>I don't think it matters if one wheel is slightly larger or smaller. The important thing is whether the wheel is cracked. (If it rings, it's not!) I have a 60-grit pink wheel from Woodcraft that I like very much. I am still using the 120-grit white wheel that came with my Delta slo-speed grinder. (It's the one that could double as a boat anchor at some 90#.) I will probably replace the white wheel with a Norton or one from Woodcraft. I will probably go with a 100-grit instead of the 120. Be sure to dress whatever wheel you get frequently with a diamond dresser. It helps immensely.
Re: Thanks folks
DD
>I use a Lee Valley white wheel and have been pleased with its performance.
Doug D
Re: It rings
Steve in NC
>Been using the Woodcraft as well. No complaints.
Thanks for posting
Bill Howatt
>Because of your post I got off my butt to find my "missing" new wheel that I had misplaced. I found it, naturally in plain sight although wrapped in cardboard, with some other odds and ends on my scroll-saw table rather than where it should have been.
It is a Norton white from LV. I don't know if it is standard Norton stock or a "special model" for LV.
