Machinists Help
Machinists Help
Machinists Help
Dave Winters, Steamboat Springs, CO
>I'm not sure what I need.. I'm trying to tap threads from the tailstock, I'm having pretty good luck chucking a tap, say 3/8-16, in the tailstock with a jacobs chuck, and then with the lathe off turning it by hand while advancing the tailstock by hand. Tough to get it right. Is there a tool that will help? What's a tapping head? Am I making any sense? My SWMBO tells me no every day. Thanks.
Re: Machinists Help
Re: Machinists Help
>Dave I get it started like you are doing or in the drill press. once it's started and running true I remove the tap from the chuck and put a handle on it and finish by hand.
Re: Machinists Help
Re: Machinists Help
Bob Fawcett
>Dave,
Taps are usually held in a tap handle. One type has a collet type chuck on the business end that grabs the square end of the tap. These usually have a round body and T handle. On most the handle can be removed (just a round bar through a hole with a sprind detent). I have one that accepts a socket drive in the other end. You could chuck a short 3/8 extension to help line up the tap to get started. Once you have about 1/4" the tap will run straight without help.
Re: Machinists Help
Re: Machinists Help
Gary Evans Tallassee, TN
>My engineer buddy showed me a pretty cool trick to start the tap straight every time. Take a 1 1/4" block of wood or plastic and drill a hole the same size as the tap body. Assuming that you are tapping a flat surface, the block gives you an easy way to hold the tap perpendicular to the surface.
Also, remember that no matter what you are making threads in, you have to stop and back the tap up occasionally in order clear the chips out of your way through the flutes of the tap. Some materials, such as stainless steel, require more of this backing up than others. Also, lubrication is important. If you are tapping wood, which I assume you are, wax might work, although I've never tapped threads in wood, so I can't speak with authority.
Gary
Re: Machinists Help
Re: Machinists Help
RussFairfield
>A slightly different way for that size tap is to lock the headstock, hold the tap in line with the hole with the tailstock center, and turn the tap with a Crecent Wrench. You will have to keep the tail-center pulled up as the tap progresses, but the two-handed motions become a habit afyer a few holes.
Most taps, other than small screws sizes have a center hole on the end. If it doesn't, you can do on of the other thing suggested.
Re: Machinists Help
Re: Machinists Help
tek-Brunswick, Ohio
>There is a problem with the way you are trying to tap. The tap must feed forward at it's own rate. The pitch of the tap threads determines that rate. Unless you advance the tailstock just right your feed rate will be either too fast or too slow and cause you to shear off threads. A hand tap should work for you unless you are tapping a great number of holes. All of the other suggestions on the board would probably work better than what you are doing. Remember to back off the tap when it binds to clear out the chips in the threads. Also make sure keep your pressure straight into the hole if you tip it to the side you can break the tap. Once you have tried to remove a broken tap, you know you want to avoid that in the future. A 3/8� tap is fairly stout and shouldn�t break too easily.
Good luck.
Tom
Re: Machinists Help
Try Candy, Flowers & Soft Music
Barry Turner
Re: Machinists Help
Re: One more option for you.
Al Crandall (NE of Indy)
>You might try not locking down the tailstock. Without a tapping head which has a linear floating spindle, you can't match the thread pitch with your tailstock spindle advancement rate. Try pushing on the tailstock by hand to keep up with the feed rate determined by the tap. Let the entire tailstock slide along the lathe bed by keeping pressure on it by hand. Some wood lathes I have seen have so much slop and the tailstock is so light that you couldn't back out a drill by sliding the tailstock while the lathe was running. These types of lathe would be poor candidates for the method I'm proposing. Sloppy lightweight machines will get you in trouble whenever you slide the tailstock for a machining operation, so you judge for yourself if it can be done on your lathe. I have tapped holes on metal lathes by sliding the tailstock back and forth using hand pressure only.
Re: Machinists Help
Maybe I'm crazy
Ron in Drums PA
>Actually I'm sure this is a crazy way to do this.
I tap bottle stopper blocks.
With a unturned block set in a chuck, I drill the right size hole to the correct depth. Then I move the tail stock out of the way and get myself ready with a the tap set in a t-handle. I turn off the lathe and wait until it slows down a little and insert the tap into the hole. If I timed it right I may have to turn the chuck about a half turn to finish cutting the threads.
So far I've turned at least 50 bottle stoppers this way and I'm still using the same tap.
Re: Machinists Help
Re: Machinists Help
Bob Elliott
>This is how I do it. The thread cutter (whatever object you may be using) is placed in the tail stock (in your case the Jacob's chuck and tap). Make sure the quill of the tailstock is NOT locked. Also, do NOT lock down the tailstock, let it "ride" freely along the ways. Use your hand wheel on the spindle to turn the object to be tapped. Place your right hand on the tailstock and "encourage" it in the direction of the headstock. Follow the normal procedure for tapping by advancing a half turn or so and then back it off to clear the chips.
I use a similar method to chuck a Christmas ornament prior to hollowing. This is a type of ornament that ends up looking like a ball shape, with NO icicle or pendant. Shape the "globe" and then drill an 11/16" starter hollowing hole to the required depth. Then remove the Jacob's chuck / drill bit and place a Oneway live center into the tailstock. Run a nail or the Oneway live center knockout rod through the pre-drilled hole in the shaft of the live center. This stops the rotation of the shaft of the live center. Bring the tailstock to the work piece / 11/16" hole. Use the procedure above to tap a 3/4" x 10 tpi thread in the "globe". Move the tailstock out of the way and hollow the "globe" in the customary manner. Finally, continue shaping / sanding the outside of the "globe" and part it off. I've found that tapping before hollowing allows the hole to be supported, as opposed to tapping after hollowing which can crack the unsupported hole.
Next, place the Oneway live center in the headstock. At this point you will have to lock the shaft of the live center with a bolt and nut arrangement. Use a bolt and nut of appropriate length because the lathe will be spinning and caution should be taken with the exposed length of the bolt/ nut (you don't want to have the live center shaft spinning). Now take the hollowed globe and screw it onto to the live center (in the headstock). I've found that it's best to screw on a 3/4" jam nut first. This provides a place for the wood to butt up against (a jam nut is about half the width of a regular nut). This only allows a few threads to be caught, but it's enough to hold the piece and finish off the bottom of the ornament. Basically, what I've come up with in this application is screw chuck.
Re: Machinists Help
You may need....
W.C. Turner
>a Micro Tapping Guide, Part # 95267472, at ww.mscdirect.com. The link below can probably answer any questions you have.
http://www.davidreedsmith.com/Articles/WoodenFaceplate/WoodenFaceplates.htm
HTH,
W.C.
Re: Machinists Help
Re: You may need....
>Wow .. Thanks all to all the great ideas. I DID try the candy and flowers, what do you suggest for the soft music? I've got some great Stan Getz...
W.C. :I like the Micro Tapping guide idea, but I don't get the idea. On the link you sent from David Reed Smith, the Guide is spring-loaded, and exerts just enough pressure? And the handle you see is a homemade deal, that has a square hole to accept the square end of the tap?
Again, thanks to all, keep 'em coming.
Dave
Re: Machinists Help
Dave..
W.C. Turner
>Just shoot him an email. He can answer your questions better than I. I've been meaning to get a micro guide, but haven't done it as yet.
Re: Machinists Help
Re: Maybe I'm crazy
Bill Hale
>Ron that sounds like a very good way to get broken fingers. If you try this on very hard wood the tap may hang and start spinning.
I tap the same way but with the lathe off and hand turn it.
Good turning and be safe
Bill in Casa Grande, AZ.
Re: Machinists Help
Steve Worcester
>I didn't understand what a tap guide was either, but a quick google search confirms your suspicions. Spring loaded, rides in the detente in the end of the tap and keeps pressure on the end.
Steve Worcester
www.turningwood.com
Re: Machinists Help
Re: Machinists Help
Fog Tanner
>Dave, I don't know if you are tapping a through hole or a blind hole. But, what has worked for me in through holes and deep blind holes is to use a three piece tapping set. the first is the starter tap and will follow the hole before cutting any deep threads, the second tap has more threads at the point and will cut the finished threads. I also use a bottoming tap for blind holes that I can use the other two taps in. I use a T-handle and have not had any problems getting the threads right if the hole is drilled straight. I thread a lot of hard maple for 1/4-20 bolts.
Once you get the threads cut, you can tape some thin hotstuff and run it down the threads. Wait till it kicks and take your bottoming tap and run it through again. Be sure that the glue has kicked or you have an art piece. I do this and use aluminum bolts for securing wings. I have never had a thread strip yet, even when they hit the ground at over 200mph....
