Photo Help
Photo Help
Photo Help
Steve in NC
>Hi folks
I know we have been here before so please excuse the repeat questions.
I am trying to do my first photo post. I took photos with my 5.2 mp camera. Down loaded to Photoshop Elements. Cropped to smallest frame and saved at smallest JPEG setting (0). The file is still too large (82 kB) Is there a way to make it smaller or do I have to lower the resolution on the camera.
Also, is there a way to put two images in the same file.
Thanks for your help.
Steve
Re: Photo Help
Re: Photo Help
Jim Terry
>Steve, In Photo Elements use "Save for Web" and then select a size (300 or so pixels) JPEG medium quality and this should yield a file of 10K to 20K which should be fine.
Jim in W-S
Re: Photo Help
Re: Photo Help
Ken Grunke from SW WI
>You should be able to get a 800 x 600 pixel image down to between 30-50 kilobytes--if the pic comes from the camera at higher than 72 dpi, change it to 72. I'm pretty sure that's in the Image Size dialog. My camera gives me pics with 180 dpi no matter what.
72 dots per inch is the standard for web images.
Re: Photo Help
Leo Van Der Loo
Re: Photo Help
Leo Van Der Loo
>Hi Steve
I use Graphic Converter, on my power Mac, but I think Photo shop has similar abilities, I take the pic's and scale them to the size I want, like 6"high, then I save them E-mail ready with the options of file size and quality, for a small picture you do not need the number of pixels that you would need for a poster size, and the monitors are not even able to show them all, even if they are in the file.
Showing more pic's in one post is a little more complicated, but if you can put on your screen and grab them and save as a picture file then you are able to put them up that way.
I have put 4 pic's here on in this file from one goblet the horizontal one was 292kb first then made into 79,9kb the large half was 77.4kb then made into 18.8kb, put together and saved and send now as a25,9kb file, try to crop off everything but what you want to show.
Re: Photo Help
Re: Photo Help Thanks
Steve in NC
>Jim Ken and Leo
Thanks for the help. I will try your suggestions. You should see a post if it works.
Steve
Re: Photo Help
Re: Photo Help
>Steve, to make two pics in one, or a montage of multiple pics, use the Canvas Size option under the Image menu. I assume PS Elements has that the same as the full version of Photoshop, but not sure.
Have both pics open in Elements, sized to the same height or width depending on whether you want them horizontally aligned or vertically.
Using the Canvas Size option, you will resize one pic, making a blank space next to it or below it, so you can copy and paste the other into that space.
In the Canvas Size option, you can choose how you want the first pic to be aligned, whether to the top, bottom, left, right, or center--by clicking on one of nine buttons.
Next, on the second pic, do a "Select All"--Ctl-A--then "Copy"--Ctl-C.
Switch to the first pic with expanded canvas, and paste the second pic in--Ctl-V. You may have to position it with the Move tool, which in Photoshop is at the top right of the Tool palette (on my computer, anyway).
Everytime I do this, Photoshop adds a new layer--I don't know if Elements has layers but if so, you'll have to merge the new layer with the first so you can save the image as a JPG. For simplicity's sake, I won't go into that unless you run into that situation and need the help. Email me, taking the "ma" from the end of my address.
If you don't run into the Layer situation, then you can do a "Save As" giving the new montage a unique name and the first image will revert back to it's original state. Or use "Save for Web" if Elements includes that.
Re: Photo Help
Re: Photo Help
MikeB
>Steve
I'm in NC also, Fayetteville. Where are you?
Re: Photo Help
Re: Photo Help
Steve in NC
>I am in Durham
Re: Photo Help
Re: Photo Help
Steve in NC
>Ken
I think you nailed my problem. I had it figured out except for merging the layers, Therefore, I was only seeing one image. I ended up doing something with "transform" but it was cumbersome. I will give this a try. Thanks
Steve
