WE MOVED...
Maple Platter- Thanks Barbara
>Here is a maple burl platter I turned from a piece of wood that Barbara sent me. I have to laugh because this piece of wood looked like something anyone but a woodturner would have thrown away. Barbara knows better so I turned something nice from it.
Re: Maple Platter- Thanks Barbara
Carole Valentine
>Wow! You did that piece of wood justice, John. Barb gets some good stuff.
Dick Parr
>That is really wonderful John, that is some beautiful wood. Great job.
George Van in WI
>I like this one John, but I am a sucker for saved wood art! I am glad you chose this form to show the grain surrounding the bowl. What is the size?
How did you light the platter and still save the forward shadow? It gives an interesting contrast and shows the figure well.
>George This is about 12" across the diagonal. I lit if from above with a 1 ft by 3 ft strip light and then bounced light back in with a mirror from below the piece. You could do the same thing at home by putting your main light above the light tent and toward the front. Then play with the mirror position until it lights the shadow under the top lip and doesn't produce glare on the rest of the piece. Sometimes this can be difficult but this piece had a flat bottom so it was easy.
If the glare on the bottom lip is too harsh move the light forward and back to see if you can reduce it. This varies in success depending on the shape of the lip. If that doesn't work try putting some thin strips of wire screen between the light souce and the lip. I use strips of wire screen about 1 or 2 inches wide and just stack them on the top of the light tent. If that doesn't work I tape them to a piece of copper wire and suspend them just above the piece so they cast a subtle shadow on the area that is too bright. About 3 strips usually works. I use various jigs to hold the wire but often a 2x4 with a hole drilled in it works well. If you try this technique with a really glossy vessel like Mark Kauder does you will see the 2x4 so you have to play with other methods. I have a ton of tricks.
George Van in WI
>Thanks John, I saved this with the photo so I can try it when I get an appropriate piece.
