WE MOVED...
ADVERTISE HERE - FREE TRIAL
Turning long piece
Turning long piece
Turning long piece
Pat Evans
>This is my first post on the turning board. I don't own a lathe and have to drive to Raleigh to borrow my brother-in-law's for the little turning I do. I need to turn a spool piece for a bed footboard. When I did the test piece, I found it extremely difficult to turn the middle section because of vibration. At 39" long, I believe there is a little flex in the piece causing it to vibrate at the middle of the length. Any suggestions for a rest of some kind to carry the middle? Something cheap, quick, and homemade since I may never have need again. At least until I get my own lathe. Thanks.
Re: Turning long piece
Carole Valentine
>Hi Pat,
What you need is a spindle steady rest. You can make one out of a couple of rollerblabe wheels. If you do a search for spindle steady rest, you can probably find some examples to go by.
Allen Neighbors
>Pat, I emailed you some pics of my steady rest. It's not specifically for spindles, but will work for them.
Allen
Rick Allen
>There are some procedural things that can help with this (read no jigs to build or "stuff" to buy).
1. Sharp tools.
2. Turn the middle first.
3. Grab the headstock end in a chuck (only cheap if you already have a chuck).
4. Reduce pressure from the tailstock (you can deduce this the most if you can implement the third item).
5. Change your angle of attack so the deflection force of the cut is going more along the length of the work piece. Using a scraper will almost always cause the deflection force to be perpendicular to the spinning wood.
Good luck
ad de Crom
>Pat, if you want do it very very easy, make a sturdy wooden hook 90 degr.
Mount on that hook a wooden block with a half round hole, of course adjustable.
Clamp this on the bed of the lathe
It's very primitive but this very simple solution will do the trick.
