ADVERTISE HERE - FREE TRIAL
Latest attempt at art
Raymond Overman in SC
>I've been wanting to do something sculptural for some time and really admire Clay Foster's work so I created the pictured piece. It's not on the grand scale or as elaborate as Foster's work but there was definitely some inspiration there.
The bowl is 10" in diamter by 4" tall of maple. The accent ring is burnished on each side. The base is 3 1/2" by 3 1/2" by 11" ipay with ebony accents. It's finished with danish oil.
Re: Latest attempt at art
Re: Nice bowl, nice base.
>Is the maple spalted?
>No, the maple isn't spalted. There is a black ring around the outside edge between the heartwood and sapwood though.
Jennifer@Indy.USA
>Hi Raymond. What a nice looking piece. I can definitely see a Clay Foster influence. I like his work a lot too. I've always wondered if and how the bowls are attached to the bases in pieces like this? Did you attach the bowl to the pedestal? Or do you leave it unattached in order to be able to use the bowl functionally? I wonder if Clay does?
Jennifer
>Thanks for the comment Jennifer. Currently it's unattached while I ponder how I want to attach it. I think there is a need for a mechanical connection instead of just a glue joint but I want to be able to position the bowl right to left or back to front before it cures to it's final resting place. I should have left a small amount of the foot on the bowl but didn't think about it until after I had turned it away. I may drill a larger hole in the base, glue a dowel into the center of the bottom of the bowl, fill the base with epoxy, and then be able to position the bowl.
This piece is actually going to be donated for a library fundraising auction along with a few smaller pieces I've been working on.
Bob Moffett
Bob Moffett
>What about embedding a earth magnet in the bottom of the bowl and a wood screw just under the surface of the pedistal?
Just a thought.
Bill Stehman
>Raymond,
Very nice and well done. Great worthy cause to boot.
>Thank you for the comments guys and gals.
