Have a question? Ask Woody!
How do strip laquer from a bowl?
Chris K in MD
>I need some help. I had a better finish on the bowl before the laquer (deft spray gloss). After the laquer was applied then sanded it still wasn't as nice. So I tried to buff (tested a small section), that took off part of the laquer finish to bare wood. So now I want to remove all the laquer. I can only think to sand the bowl again removing the film of laquer in the process. Any help would be much appreciated.
Re: How do strip laquer from a bowl?
Wipe it off with lacquer thinner and scotch brit
Phil Joines Krum,Tx
Allen Neighbors
>Chris, lots of airflow, rubber gloves, larger bowl filled with lacquer thinner, and a couple of clean rags. Dip the lacquered bowl in the lacquer thinner, for a minute or so, then use a clean rag... dip it in lacquer thinner and rub the lacquer from the bowl. Use another rag, and keep on washing with lacquer thinner, until the finish is off the bowl. The wood will be sealed, and well, but then you can finish it again, the way you want.
AL
Chris K in MD
>Thank you Phil and Allen. Allen I hope you are feeling better!
Allen Neighbors
>Thanks, Chris, I am now. I had to go back to the hospital for four more days. They let me out the first time with a leak. Now my body has to absorb a large hemotoma, plus, they had to give me two units of packed red blood cells to get me a little strength back. On the mend, now. PTL!
Allen
