Jet Mini - Morse Taper - What size?
Joe in a Cleveland suburb
>Hello.
I would like to get a drill bit chuck thingy for my Jet Mini. Do I need a #1 or #2 morse taper?
I made a collet thing then tried to drill a hole in the center. Thought I could use my drill. It didn't work. So I made another one and tried to use my drill press. The hole ended up off center. So I turned a 3rd one and would like to try and get the hole centered this time(!).
Boy. You know? This sure is a lot of work just to make a Shaker peg and knob... :)
BTW. Dumb question. But why is it called a morse taper? That is, if I'm calling it the right thing...
Thank you,
Joe
Re: Jet Mini - Morse Taper - What size?
Don Henthorn
Re: Jet Mini - Morse Taper - What size? *LINK*
Phil Joines Krum,Tx
>Both the head and tail stock swallows are #2MT.
The link is to a 1/2" chuck on a #2 arbor. I have 3 of these and they all work fine.
Up to about 3/8" you can just put a handle on the bit and drill them by hand with the lathe turning the work. Use the tip of the skew or spindle gouge to make a starting dimple.
Little Machine Shop chuck
>Joe You need a #2 morse taper. Your drill press may have one. If you have a drift punch that came with the drill press you extend the quill feed and push the punch in the slot. You may have to twist the chuck to get the inside slot to align with the outside. Push the punch in this slot and tap it with a hammer. The chuck and morse taper should drop out. This will work in the jet but you will have to extend the quill feed in the tailstock. Normal #2 morse tapers are too long to work with the quill feed fully retracted. If your drill press doesn't have a morse taper on the chuck or has a different size then you'll have to get one. It's a really handy device for turning.
By the way a drill chuck doesn't work for chucking wood in the lathe. You can do small things if your careful but the jaws tend to crush the wood and won't hold solidly.
Re: "Why is it called a Morse taper?" you ask.
Al Crandall (NE of Indy)
>The man who invented the twist drill, Stephen A. Morse, also invented a cone in a cone taper locking system for his new drills. The tapers were originally a percentage of the increase of the radius versus one inch of length. Time passed and the "2% taper" became the #2 taper. If I ever invent anything as useful as the morse taper, you can bet that I'll call it the Crandall Whatever-It-Is.
Morse taper and other info
Jim Pugh, Ohio
>Joe, do yourself a favor and go to the library and check out their copy of "Machinery's Handbook". It will tell you all about Morse tapers, their sizes and other related information. You will also find that there are other named tapers altho none are used on wood lathes (to my knowledge). You will find charts for every kind of thread, taps for same, tap drill sizes, clearance hole sizes, and hundreds of pages of other interesting things.
Thanks Al.
>Thanks all. I know what to get now.
Joe
How about John Crapper
Phil Joines Krum,Tx
>He invented the flush toilet. :>(
Re: How about John Crapper - fiction? *LINK*
JKJ in East TN
>Snopes indicates it was Thomas and he had plumbing patents, but not for that.
Snopes, Crapper
#2 Crandall Whatever-It-Is *LINK*
JKJ in East TN
I've been thinking about building a #2 Crandall Whatever-It-Is to go on the trailer hitch receiver for loading small logs. I hope I don't owe a big licensing fee.
Whatever-It-Is
Re: That was a compilation of other's ideas.
>I'm impressed by your memory. And also that you can drag up that old post of mine after so long a time. I couldn't do it. That rig is not my invention, but just a compilation of ideas which were already out there. Nothing very original on my part other than puting it all together in one place.
If you are serious about building one, I suggest you use your forum search skills to find the post I made back around Christmas where I showed the 12 volt winch I added to the crane arm. It has increased the utility of this rig by a factor of 4 or 5. Another change I have made is I now use a chain cinch to wrap around the logs. Much faster than messing with the ratchet strap. Still buying all the components from H.F. I'm keeping my fingers crossed on the durability of the H.F. winch, but so far it has been a real workhorse.
Hi Jim and Thanks.
Al's #3 Whatever-It-Is (with winch) *LINK*
JKJ in East TN
>I remember that thread. The winch was a great addition.
I actually want one for my 1-ton flatbed truck, but I was looking for something a little more substantial so I can load bigger logs as well. (The one I'd really like to get is hydraulic and goes for about $15000! Ha.) I'd like to lift at least 3000lbs. What I usually have to do now is haul the tractor on a trailer behind the truck just to load the logs on the truck, and even then I struggle with heavier logs.
The heavier cranes I found were pretty expensive so I'm thinking of building my own perhaps sometime this summer. I'm thinking of a vertical post made from 4" steel pipe seated in a support such that it can rotate, with a braced horizontal I-beam on top with a chain hoist that can be moved to several positions along the I-beam. Rather than a hitch mount, I'm thinking of mounting it on the top of the bed up near the passenger door. I do have an extra 8000 lb winch which would make it a lot easier to operate and probably let me load logs by myself. (The electric hoists I've seen were pretty high and bulky as well, requiring a taller post.)
Have you tried skidding tongs for lifting chunks of wood? One large (25") is about $90 or so and it saves a lot of time. I often use two tongs fastened with short chains to hooks welded on my front end loader, but I'm limited to about 1300 lbs. Note that skidding tongs are not rated for lifting, so they will get you a citation if used commercially.
BTW, I do use chains for a lot of wood moving (except when using tongs). I learned a little trick from a guy recently - use a bolt, link, or clevis to make a loop in the chain adjacent to one hook. This is quicker and more flexible than making a loop by hooking the chain on itself. You can slip a fork tine through the loop, hook it over a tooth on a bucket, or use it as a slip ring for cinching. (When I make a loop with a hook, half the time the hook comes loose before I get tension on the chain!)
Al's crane with winch
Bob Fawcett
>Stephen A. Morse, an enterprising mechanic, developed a new and better way to drill a hole when he invented the twist drill. With a new patent and a stockholder investment of $30,000, he opened the Morse Twist Drill and Machine Company in New Bedford Massachusetts in 1864.
Recognizing the need for a way to drive his twist drill, Morse created the taper shank series. Two sets of master gages were made up; one, sent to the Bureau of Standards in Washington, D.C., was accepted as a National Standard. The other remains with the Morse company. Differences with his board caused Morse to resign in 1868.
I got this from morsecuttingtools.com
