Jet mini Tailstock fix
>One of the problems with the jet mini is the tailstock slips. To get around this I made a bigger tailstock locking plate. I screwed a 1 �� x 1/8� x 4� long piece of mild steel to a 2� X �� x4� piece of mild still. Then I drilled a hole �� in diameter for the locking screw.
To keep the plate from rotating and to make it easier to get on and off I drilled a 1/8� hole in the tailstock and inserted a roll pin. I put a spring on this to keep the locking plate �open�. This makes it easier slide the tailstock on and off.
Before I screwed the 1/8� piece to the big piece I draw filed the large piece to flatten it and remove the scale. If you bought metal that was cold rolled it wouldn�t have this scale but you still need to check to see if the metal is flat. It�s the size and the flatness that makes it work as a locking plate. Mine isn�t perfect, it slips when you apply a lot of pressure but it�s sure better than the smaller plate. If you wanted one that really works take a piece of 3/8� metal and have it machined so there is a 1 �� raised strip. This will be flat and will lock more securely.
