OneWay Easy core
OneWay Easy core
OneWay Easy core
RPE
>I have read on the OneWay site that the knives to the easy core will cut 2" larger and 2" smaller than the listed knife size. So that means I can get a 7-11" bowls from the 9" knife?
Is it true?
Thanks for your help.
RP
Re: OneWay Easy core
Leo Van Der Loo
Leo Van Der Loo
>Hi RP
We have a professional turner in our turners club here, Doug Magrath and he makes and sells his one person salad bowls made with the Oneway corer, they are 6" that's the smallest he can make them.
Have fun and take care
Leo Van Der Loo
Bill Neddow
>Yes, that is right. But,if you use a 9" knife to try to hollow an 11" bowl, you are going to get a shallower bowl than if you were making a 9" one. Remember, you only have so much metal in the knife. If you go wide, you are going to have to compensate by going shallower -- othewise you will run out of knive before you get to the bottom.
Similarly, if you make a smaller bowl than 9" with a 9" knive, the tendency is to make a deeper bowl. This is great if it is what you want. But you can also go through the bottom of the bowl. Just use the easy Oneway instructions for establishing the depth of your cut and you will avoid this.
