Re: Drano
RussFairfield
>There are a lot of things you can do to darken Cherry. I have listed a few of the common ones. Take your choice. Read my warning before doing anything.
Warning:
Anything we do to artifically enhance or accelerate the aged coloring of wood may also enhance any blotchy appearance that might result from variation in the grain direction. It will go away in time, but it will most likely look worse in the beginning, and take longer to arrive at an even coloration, than if you had done nothing. This is particularly true for Cherry.
Setting it in the sun has alrady been mentioned.
New wood can be very quickly toned to it's natural aged look by wiping it with 1 tablespoon Drano mixed into 1 cup water.
Substitute Tri-Sodium Phosphate (TSP) for the Drano and use 2-tablespoons per cup of water.
Use a finish that is based on Boiled Linseed Oil because it gets darker faster than other finishes. Minwax "Antique Oil" finish in the red can would be a good choice for a commercial product.
Use any of the Watco Danish Oil finishes that are colored. There is a "Cherry" available, but "Walnut" will give you a darker color.
Give it couple coats of shellac, mixed from the darkest Seed-Lac or Button-Lac flakes you can find, before applying your oil finish.
Look through the selection of stains in the Minwax display at the Home Depot. Golden Oak would be good for a mild coloring. Just remember that Cherry will be 1 or 2 shades darker than the sample sticks at the store.
Rub Brown Kiwi shoe polish into the wood before application of the oil finish.
Time is still the best way to age Cherry.
