A55 Smoothing Plane
Finally!
Finally!
Finally!
Carole Valentine
>I finally got around to making a "Bill Huber" frame for a light tent today. The elbows at the top of the legs are not glued to the top frame so I can fold them for storage or put different size legs on. Not being glued also allows me to set the frame on uneven surfaces. There are three screws on the back rail of the top frame that allow the background to be hung. I have stolen one of my Mom's sheets, now I just need to find some lights. This was so easy, I don't know why I kept putting it off.
Re: Finally!
Re: Finally!
Jim Shaver - Oakville, Ontario
>Hi Carole,
A light box is a simple and wonderful thing for showing our work...another turning tool!!
Take care,
Jim
Re: Finally!
Re: Finally!
>Carole Good job. See if you can find a quartz halogen work lights. You can get buy with one light if you use reflectors but most people end up using 2. They are about 300 watt and work well with digital cameras if you use the tungsten setting and a tripod.
Re: Finally!
Re: Finally!
Carole Valentine
>Hi John,
I have a double work light that my cousin borrowed from me. Going to have to get that thing back and pick up another one as well. Then I should be good to go, since I already have a tripod. Of course my old camera gives me fits, but that is another story.
Re: Finally!
Tungsten?
George (Oxford, NC)
>OK, I admit I'm a photographic (as well as computer) dummie and a turning novice. What is the 'tungsten setting' on a digital camera? Is it only on high end cameras or does my little Kodak 6230 have one?
George
Re: Finally!
Re: Tungsten?
Carole Valentine
>Hi George,
I know you don't want to hear this, but all I can tell you is read the manual for your camera. :) My camera is about 6 years old but it has two settings for flourescent (don't know the difference yet but one works better than the other) and other settings for tungsten (regular lightbulbs), daylight, etc. Yours probably does too.
Re: Finally!
Re: Finally!
>Carole If you have a double light, take one light off the light stand and use that for your second light. I made a little stand out of wood for the second light. You can rig up just about anything to hold the second light. I built a wooden stand, partially turned of course.
Re: Finally!
Re: Tungsten?
>I agree with carol. I don't know all the cameras out there by any means but many have settings for the White Balance for Daylight, flash, tungsten, and flourescent. If your doesn't it may have an auto setting that often gets it pretty close.
Re: Finally!
Re: Finally!
Chip Sutherland
>THANK YOU!! I wasted an hour turning time trying to get the right lighting, props and supports for my 1st posting picture here on WC. I was using 2 towel racks, a safety pin and my wife to get the backdrop straight. I ended up posting a picture that has a shadow on it from the cabinet overhead. My daughter is being confirmed tomorrow so I doubt I'll have time to run to the orange borg to get the pvc and elbows.
Re: Finally!
Here's the link to what you need *LINK*
Carole Valentine
>I hope I am not doing anything wrong by posting the link.
Huber's light tent
Re: Finally!
Re: Here's the link to what you need
JKJ in East TN
What, technically, socially, morally or legally wrong? It's hard to imagine how that could be! The web site is public and the idea is hardly original. Very nice web site and most excellent instruction, though.
Re: Finally!
Re: Finally!
Charles Bjorgen
>Carol -- I agree with John's suggestion to remove the second lamp head and use it as a secondary light for filling in shadow detail. If you'd prefer to keep your work light setup intact, then you might want to just turn off one of the light heads to avoid two sets of conflicting shadows coming from the same general direction.
I just went through a photography small group session with several members of my Minnesota turning club yesterday and we discussed that same situation. I also suggested they read their camera manuals to set the white balance feature to "Automatic." That setting has always served me well, although one member brought a camera that had no white balance setting. I assumed it was factory set to automatic.
