Re: Is it a collet chuck or scroll chuck?
Al Crandall (NE of Indy)
>Collet chucks generally are designed to grasp diameters smaller than you might use to hold a bowl with. Scroll chucks, on the other hand, will grasp diameters up to around 6 inches. Some scroll chucks are tightened with "tommy bars" and some are key driven. Some key driven chucks tighten the same direction as other chucks do when they are being loosened. A little more information might help us to help you.
A collet chuck will usually have a right hand thread on the collar which closes the collet. Does it have a spanner wrench to apply pressure to the collar? Are you sure you are turning it CCW? If you really need help with a scroll chuck, tell us the brand.
