25 Cypress spindles
25 Cypress spindles
25 Cypress spindles
OB OBrien In Pensacola
>This is the project I just finished. 25 Cypress spindles for a part of the hurricane restoration on a 100 year old house in the historic district of Pensacola.
Re: 25 Cypress spindles
By the time you finish with 25
Don Henthorn
>it gets to be "old hat." They look pretty uniform from here. Did you turn them all freehand or did you use a duplicator?
Re: By the time you finish with 25
>All freehand. 1/2 way through I got tired of doing them and got a duplicator. The one I got wouldn't fit my lathe so I had to order new mounting brackets. They came in today about 5 hours after I finished. OH well. Next job, maybe I'll get to use the duplicator.
richard dombroski
>By the time you got to the last ones how long was it taking to turn and sand one.
>It got down to about 20 minutes from start to finish for each one.
duplicator ........ ?
Ruth Niles
>OB,
I'd be curious to know how you like a duplicator. I've done hundreds of reproduction spindles, bought a duplicator, used it on 2 spindles, sold it. It ended up being MORE work (for me) than doing them free hand. I had to go over the whole spindle to fine-tune it and smooth out the roughness so it was actually much quicker to do the whole spindle free-hand.
Re: duplicator ........ ?
>Hi Ruth; Don't know yet. I haven't hooked it up and tried it yet. A frind of mine has the utility model and has been able to use it quite well. He said you did need to sand quite a bit. I understand if you mount it on the back side of the lathe and turn the cutter upside down or run the lathe in reverse, it will do most of the work quickly, then you, quick run around to the other side and finish em off (;^}.
Did you use yours on hard woods or soft ones ?
Pretty good,
Jorge Castaneda
>20 minutes for a spindle is good, maybe you have a future in restauration work, a friend of mine is all that he does and makes a very good living.
Tony - Memphis
>Nice work! I picked up a bunch of old spindles and finials at a salveage place inNew Orleans a few years ago that were all cypress. Hey, my dad was born and bread in Pensacola. I still have a ton of family there. Spent many happy summer weekends there. We were suposed to stop there on our way to Seaside last fall, but the roads were all closed in MS, so we went the Al route instead. Anyway, I have an uncle that lives over close to Five Flags that does some woodworking.
Tony
