sharpening a Glaser 5/8 bowl gouge
James Gealy
>I posted this on the wrong forum earlier this week and it was recommended I try the turning forum for a better response. Can anyone help?
My new Glaser 5/8 inch A11 deep bowl gouge finally needs sharpening. I've got seeded gel stones on an 8 inch grinder and a Wolverine sharpening system but I'll be danged if I can figure out the geometry to create the same grind as what came from the factory. Am I going to have to buy a Glaser floor-mounted jig? Any way I can do this grind with something I can put on the Wolverine? Anyone have any info as to the angle between the tool and the jig leg, the length the tip of the tool extends beyond the jig, the length of the jig tail, etc? Any help would be appreciated. Thanks.
Re: sharpening a Glaser 5/8 bowl gouge
T Daniel
>James, don't let that sucker beat you. Look at our grinds library first. All any jig will do is give you a nose angle and a side angle; everything else is hand/eye coordination. You must know what you want before going to the grinder. The jig will not guarantee you what you want. It will assist you in getting the grind you want. For me Glasers are hard to sharpen becuase they want to be pointed and I do not like a pointed gouge. Just remember, there are no stops on any of the jigs so if you hold the metal to the grinder it will be taken off and that changes the profile. Get the picture in your mind of what you want; then set the nose angle and the side angle. From there on it is hand/eye coordination.
Kenny in Indep
>Hello, in the above post you talked about nose angle and side angle. I assume you set the nose angle by movement to and away from the grinder with the V-arm and side angle by adjusting the angle of the vari-grind jig. Thanks for the help for this dumb old country boy.
Gary Evans Tallassee, TN
>James,
When I set up my vari-grind to sharpen my Ellsworth gouge, I used the old magic marker/unplugged grinder method. Color the ground part of the gouge, adjust the vari-grind so that it looks about right and then turn the wheel by hand to see where the gouge is actually touching the wheel. Adjust as necessary. I think the directions I used came from Wolverine, but won't swear to it. I know I've seen them on the web.
As I recall, it took some time to set it up so that it was right, but then you can mark the vari-grind with the correct angle and measure the extension so that you can duplicate each time you sharpen.
Gary
George Van in WI
>Kenny, there is a good video available on Oneway's website under Multi-media if you are interested.
Wally Dickerman in Arizona
>James, the grind that you use on your gouge doesn't have to be the same as was ground at the factory. I have a couple of Glaser gouges but I've ground them them the way I want them so I don't know what nose angle J. Glaser uses. The instructions that you received with your Wolverine are pretty good. As they suggest, a 1-3/4 in. setting for the amount the tool extends is good. For a 5/8 in. gouge I set the leg at about mid point to get a 60 degree nose angle. Slide the V-arm in or out to get that angle (or whatever angle you choose).
For a side grind, grind the sides first, working your way around to the nose. Be sure that the profile is straight or a little convex. I prefer convex. Never concave.
Once you have the Wolverine settings the way you want them, make some marks with a sharp tool of some sort, so that you always get the exact same grind. Then, every time you put on a new, sharp edge, it's only a touch-up.
Wally
James Brooks in GA.
>James, I ground mine the same as my Ellsworth gouge with the same sorby jig.
Greg in Oshkosh
>the first time I had to use the Wolverine to sharpen my ellsworth I found that I couldn't get it set correctly. That's because the ellsworth jig has the pivot point at the back and the wolverine at the front. I had to extent the gouge out about 3" not 1.75. You may have to change that 1.75" stick out for your glaser as well as the pivot angle and the holder. Good luck
