ADVERTISE HERE - FREE TRIAL
Certainly It Shouldn't Be This Difficult
Barbara Gill, Remlik VA
>I just finished hollowing a piece of green walnut. I have the Kelton rig. The vase is about medium size, 6" deep. I am not having difficulty with the cutters cutting; the problem is manuvering the rig. Obviously I am not doing something right. Hmmm anyone want to demo using the Kelton rig at The Gathering?
Re: Certainly It Shouldn't Be This Difficult
Rick Davenport
>I noticed there is going to be a nested bowl demo in Lousville.
Are you going there too?
Rick
>No I am not going to the National Symposium. I am not sure what the nesting bowls have to do with hollowing?
Carole Valentine
>Barb,
I tried Dick's Kelton Rig and found it a little awkward, of course I did not use it long enough to give it a chance. I have a hollowing gate and I don't even use that. I prefer to use my Keltons free hand, especially on a 6" HF. Of course this doesn't answer your question so I will shut up now! ;)
RussFairfield
>Two things that might help.
Loosen up the bars. Make sure there are no tight spots. A little slop doesn't hurt anything. The rig will twist into the cross bars and take up any gap. Most of the time it won't move at all.
Lubrication helps. Make sure all of the bars are clean, and then lubricate them. Teflon dry lubricant works. I use Liquid Wrench because it is a good lubricant, and doesn't collect dust like an oil. Keep the bars wet. It doesn't take much. Wipe them off when done using.
>Carole, I appreciate your imput. :-)
Thanks Russ
>Tomorrow I will use all of your suggestions.
Rick Davenport
>Sorry Barbara, I keep getting the two McNaughton tools mixed up.
Never Mind.
Re: Thanks Russ
>Barbara I'm not familiar with the Kelton rig but on my homemade rig I find that the position of the captured tool rest has to be adjusted depending on the shape of the vessel. it's either that or switching to the curved bars to clean up under the neck.
I use candle wax to lubricate my bars. Whatever you use the bar should slide effortlessly.
Dick Hines
Dick Hines
>Barbara, do you have the hollowing rig or are you just using the gate
You should have come to the Jan meeting. Jim Bumpas did a demo. Not with the Kelton but you have gotten the idea.
If things work out next weekend I may be able to get over to your place to see Dan's bike and if you have time I can try to help you out. Of course you will have to give me a ride to your shop. I am not rideing my bike down that long dirt road.
That's the best offer I can give you.
>Dick, Taylor and I are leaving for Jacksonville FL next Sat. morning for a week with Shelley, our oldest daughter. I hate that I will miss seeing you.
OB OBrien In Pensacola
>Barbara, Russ gave you some good info on things to do, here's another one. As I remember the Kelton rig has a black handle bar grip on the end of the boring bar holder. A friend of mine used to have one and he was trying to hollow by standing behind and holding the handle and pushing in and out. I showed him how to stand parallel to the whole rig, put your left hand on the hollowing bar on the tool rest and your right hand on the back of the rig by the black handle. Use your left hand to guide the cutter back and forth and your right hand to push it in and out. If you need more info I have a detailed discription with pictures on how to hollow with my hollowing rig. It's the same principle. If your going to the WC gathering, I will be demoing this technique and would be glad to show you the finer points. Hope all this helps. Good luck. OB
>It does OB. I do stand beside the rig, not at the end. Mine does not have a handle though. I hold the front with my left hand near the rig and guide with my right at the back. I am sure a handle would help.
Don Tewell
>"I'm not riding my bike down that long dirt road" sounds like the lyrics to a country and western song. Or should.
I Think I Will Turn A Handle Tomorrow.
Re: I use candle wax to lube tool rest and trap
Al Crandall (NE of Indy)
Re: Certainly It Shouldn't Be This Difficult *LINK*
George Van in WI
>Barb, I just started using my Kelton Hollower and it too got hard to move. I put Johnson�s paste wax on the tubes and the problem was solved. I stand at the side and control the boring bar by squeezing as shown by John Jordan with my right hand on the rear of the tubes but not on the end. So far I am pleased with the tool however I have never used any other captured rig and have only roughed out forms to dry and later return. I am going to get the UHMW adhesive tape, put a strip on the top, and bottom as suggested by Greg Jensen for a permanent solution.
Hartville Tool
Thanks
Jorge Castaneda
>Barbara,
Mac will be at the gathering, he is very good hollowing, talk to him
Jorge
