Double Faced Tape "knife"
Darryl Hansen
>On occasion I turn Corian and wood disks to fit compacts, box tops etc. I usually use double faced tape to hold the blank on the mandrel or faceplate. Most instructions say to use a sharp insturment or putty knife and pry the turned object loose. I found a better way. I use a length of fishing line. We use "Spider Wire" here on the Bay. It is spun kevlar and is super strong. A 50# test line is the diameter of 6# monofilimaent plastic line. Wrap a length of line around a piece of dowel or rod. Overwrap the ends 'cause the stuff is slippery and won't hold a knot. Wrap the line around the mandrel and criss-cross the ends at the top and pull. It will cut the double face tape without putting any pressure on the turning.
Re: Double Faced Tape "knife"
Mike Schwing from Md.
>Not to mention that it'll cut through your fingers right to the bone in a second or two when a big striper is yanking on the drag. That stuff is incredibly thin , sharp, and strong!
JKJ in East TN
>Nice tip. I was taught to use acetone with a syringe then pry, but I'd like to try your method. I wonder if the line you mention is available away from the coast.
Darryl Hansen
>It is available at Wal-Mart and K mart around here so probably can be obtained in other places. If not drop me an email and I'll send you some.
adrien
>That's the way potters take their wet clay vessels off the wheel!
Wally Dickerman in Arizona
>I use double faced tape when turning platters. I have a very simple way of removing the finished platter from the faceplate. I turned a wooden plug about 1/2 inch thick and just under the diameter of the hole in the faceplate. To remove the platter I simply insert the plug inside the threaded hole in the faceplate. I slowly thread the faceplate onto the spindle. The plug just pushes the platter off the faceplater. No fuss no muss. I use the same method when I'm turning a collar to be installed on a hollow form.
A friend saw me use this method when turning a platter. He sent it to Wood mag. They sent me a check for $75. I later sent it to American Woodturner for their tips section.
Wally
