Small Maple Bowl
Small Maple Bowl
Small Maple Bowl
Chris DiCiaccio
>Well, this is my first "John Hart blank". It's one of the smaller pieces of maple he sent me. John, I still need more practice on bowls. Thanks again for the blanks. I'm not too satisfied with my work on this one, I've got to get my confidence up for making the wall thinner. This one is only about 3/8" which is still too thick for this small piece which is 4"h x 3 1/2"w. I'm not sure I fully understand using the irish grind bowl gouge yet. Anyway have a great day folks, keep posting your work so I can learn from looking.
Re: Small Maple Bowl
Chris DiCiaccio
Rick Davenport
>That bowl looks good.
And since you still have the tenon, and the wood looks pretty solid, why not go for another quarter inch or so?
Rick
Jim Pugh, Ohio
>Chris, one of the things I did early on was to make bowls that were deep in relation to diameter and it looks like you are doing the same thing. Nothing wrong with it but just more difficult to accomplish. One of the things you run into is keeping the bevel rubbing while cutting the inside bottom because the handle hits the top edge of the bowl and you lose the bevel. Wider bowls don't have this problem. One suggestion is to have a second bowl gouge with a relatively blunt bevel angle just to use in the bottom third of the bowl.
Jim
Chris DiCiaccio
>Jim, I think you are right. It got a little deep and I had a bad catch or dig, don't know the difference yet. I had the flute up and was cutting from the bottom back along the side toward the mouth when it happened.(sliding the gouge out toward me) (Irish grind). Anyway, thanks for the council.
Re: Jim
GaryG in MD
>Chris,
I had a catch with a "pull" cut too. That's another story.
A thought for you: In order to get the smoothest cut (less tear-out or roughness on the end grain) you want the wood fibers you are cutting into to be supported by the fibers yet uncut. In order to do this, if you are working on the inside of a bowl with side grain orientation (i.e., not an end-grain bowl orientation), you want to cut from the rim to the center. On the outside, it is the reverse -- from the center to the rim (although the tail stock gets in the way near the middle of the bowl. Going in the opposite directions often leads to those spots of torn end grain which need a lot of sanding -- and then you get sanding ridges if you're working with a coarse-grained wood (like oak and many others). It's best to try to cut in the correct direction as much as possible -- certainly as you are approaching within 1/8" or 3/16" of your final thickness.
On a tall bowl, the transition from the side to the bottom is difficult. Jim is quite correct that it is good to have a bowl gouge with a steep (blunt) angle (I use 65 or 70 degrees). Even so, you have to go in very carefully, cutting with the left side of the flute as you move down and then give your wrist a twist to the right as you merge with the bottom. Otherwise, WHANG! It's a tricky and dangerous maneuver -- for me anyway (also a beginner).
Keep practicing -- you'll get it.
Gary
Re: Jim
JKJ in East TN
>>...On a tall bowl, the transition from the side
A sharp scraper is sometimes good for this.
Re: Jim
Ed Moore
>There is an excellent article by Nick Cook in the recently arrived AAW Journal on 20 things not to do when turning a bowl. One thing specifically mentioned for new turners is NOT to turn a deep bowl with vertical walls. Start with SHALLOW and grow from there.
The hidden message I see in that concept is "Learn to crawl before you try to run." Then the suggestions about how to turn a deeper bowl will make more sense to you. You will have a better foundation upon which to build.
Nick's article is highly recommended.
Ed
Chris DiCiaccio
>To all of you: This is very helpful for me. Thank you so much for the council. Anyone else please feel free to chime in.
Re: Jim
GaryG in MD
>You're right, John. It's just that I feel like that's cheating. If I always defer to the scraper, how will I ever learn the more difficult cuts with the gouge? That's a rhetorical question -- what I actually do is try to use the bowl gouge as much as I can until the sounds start getting scary (if I'm lucky) and then switch to the scraper feeling that I have "learned" as much as I can at that juncture. I still get a lot of mileage out of my 1" round nose.
;-) ...Gary
Re: Jim
GaryG in MD
>Ed,
Now if my issue would just come in the mail, I could get on with some good reading. ...
That's a good suggestion. It makes me smile because in my newbie ignorance, one of my first rough-outs was a big hunk of red oak which I turned with vertical walls! Now I understand -- tough wood and tough shape. It makes me cringe just thinking about it. Somehow I got through it -- with the trusty round nose. Funny thing -- it's still sitting in the pile waiting to be finished. Maybe one of these days I'll get up the nerve to tackle it again.
...Gary
