Sanding Green Natural Edge Bowl
Doug Reynolds in Seattle
>My turning club recently made a trip to rescue some Yew and others species (maple, holly, sumac, dogwood) from the power company. The Yew is pretty small (4 - 6 inch diameter) but, very pretty, so I am trying my hand at natural edge bowls. Wood is green. So, should I rough out and wait for it to dry before sanding? Normally, I would slow the speed down to power sand but, with the "wings" all I get is sort of a BANG-BANG as the sander recontacts the wood. Should I increase the lathe's speed? How does one sand by hand with these "wings"? One of the club members said he cuts the logs slightly longer and ends up with really long "wings". A test of skill and nerves.
Wood there be a better use for Yew that small in diameter?
Re: Sanding Green Natural Edge Bowl
>Doug I sand natural edge bowls with the power off. It can be done with the power on but you have to be really really careful. It's just a lot safer on you and the bowl with the power off. It's also very easy to round over or thin the edges when power sanding.
Re: Do what John said
RussFairfield
>Turn the lathe off before sanding.
I turn to finished thickness and rough sand while wet. Let it dry, and then sand and finish.
You don't need to use another wood. You will find that the Yew is the most mild mannered wood you can find, and that it sands and finishes better than almost anything else you could use.
The only ptoblem with Yew is that larger sizes have a problem with ring shake, so you may have some repairs to make after it has dried.
>Doug I had to stop and do a photo shoot so I couldn't finish my thought. When you hand sand on the lathe the bowl wants to rotate, especially if you are power sanding with a drill. If you have indexing on your lathe just use that. If you don't you need to somehow stabilize the lathe so it won't rotate. I had a strap that I put over the chuck and hung a weight from it. This provided enough friction to stop the lathe from rotating. I gave the strap to my son so now I have to come up with another solution. I'm thinking about a big bungee cord. I will probably build an indexing system for this lathe shortly.
If there are any lathe manufacturers listening we could sure use some sort of locking brake for this operation. I think my Nova Comet had the best set up. The indexing is also the spindle lock so you can lock the spindle anywhere you want for sanding, removing the chuck or indexing. I questioned the tech rep on how this might be weak because the pin isn't that large. He said I would never break it and sure enough, I've used the heck out of that lathe for about 8 years now and nothing has gone bad. Other manufacturers should take not. This is a great feature and cost very little to add to the lathe.
Re: Sanding Natural Edge: Drill Press
Devo
>I learned this tip from Barb Crockett a few weeks back. I don't even sand it on the lathe. I finish it, remove the tenon, and mount a sanding pad on the drill press, then I move the bowl around the pad. Makes it much easier to control and I can see what I'm doing - cut my sanding time in half, with even less effort, and less risk to the bark.
- Devo
Attached, 12" Black Locust, watco teak oil finish
>Sounds like the ticket. I've got "sanding mops" in various grits that mount on the drill press then, can finish up on the Beall buffing system. Thanks for everyone's help.
Devon Palmer
>What a great idea, never thought of a sanding mop. Yay, another excuse to spend money LOL Could get a few grits and batch sand them.
