A55 Smoothing Plane
Turning a pipe (the smoking kind)
Devon Palmer
>All,
I've been thinking about experimenting with some Briar to turn pipes? How would you hold onto the thing? Escoulen Chuck? Any advice or links would be appreciated....
- Devon, Columbus, Ohio
Re: Turning a pipe (the smoking kind)
Jorge Castaneda
>Devon,
I never turned one, but my mechanichal mind tells me to rough the blank in a band saw, so thete is a hexagon with the stem protruding from a side, then between points, bore the stem and shape it, then also beween points shape the outside bowl partially and there will be a certain amount of work to be done by hand, once the bowl is done in the outside, a jam chuck with a slot to house the stem and there you hollow it, it should be fun.
good luck
Jorge
Re: Turning a pipe (the smoking kind) *LINK*
Dennis Daudelin
>I've never seen a link to turning a smoking pipe but it could look a lot like this coffee scoop which was make on a homemade wood chuck (with the handle turning like a propeller)
Check out this link and see if it helps at all??
Maybe your photos could be the first smoking pipe project?
Dennis
Coffee Scoop with homemade chuck
>At the risk of sounding heretical - why turn a pipe? It would seem to me to be better to rough out the blank on a bandsaw and then rough it into shape with a drawknife. Finish it with a spokeshave.
Re: pipe turning (sort of)
Brian Simmons, Heflin, AL
>It looks similar to a pipe. I turned the inside first and then chucked between centers to turn along the long axis. Was watching TV one night and an image of this thing popped in my mind. Drew a sketch so that I would not forget and made it the next day. I gave it to my mom for her to display one of the tiny bird nests she has found over the years
Bill Howatt
>Thanks for posting the link. I was trying to figure out how to do a scoop in 1 piece and then I saw your post. Duh, simple when you know how!
Bill
