Tailstock Troubles
Tailstock Troubles
Tailstock Troubles
Ryan Dicker in Renfrew, Ontario
>Hi,
I seem to have run into a problem with my tailstock not being able to tighten against a piece. Once the center begins to extert any pressure on the piece, the handwheel no longer moves the quill ahead. Either the handle has become loose or the tailstock screw is stripped. I have a General International Mini (25-100) that is still under warrentee.
Any suggestions would be appreciated.
Thanks,
Ryan
Re: Tailstock Troubles
>I'm not familiar with that lathe so I'm guessing. Have you checked for set screws in the handwheel. They often come loose, that happens in my jet. Some mini lathes have a short throw on the tailstock quill. If you extended it past the screw threads it won't screw out anymore.
Some lathes have a pin that stop the outside portion of the quil from turning this lets the inside portion screw the outside portion out. If this is missing or loose the outside can spin and the quil won't extend.
Those are my best quess's.
Ken Grunke from SW WI
>Our club has this lathe and I had it in my shop for almost a year.
The setscrews for this lathe are very tiny, and I always had trouble with them coming loose. Mostly on the motor or spindle handwheel. If I remember correctly, there are two setcrews on those parts, I never had trouble with the tailstock wheel but I'd assume the same.
The tailstock ram screw is either 18 tpi or .75 mm which would take a lot of force to strip, so that's not likely.
gil jones
>Contact Trevor Fournier at 1-888-949-1161 ext-33, or email at trevor.fournier@general.ca
Trevor is a service manager for General International. If you call, the phone is answered in French, but they can switch to English for you.
>Well, It turns out it was just the setscrews that had came loose. Hadn't even realised how small they were until I tried to find the allen wrench for it. Thanks to those who responded.
Ryan
General lathe OT
Derek in Dundas
>Ryan I am in the process of deciding on a new lathe. The general seems like a good buy, oddly close in design to the Jet. How do you like the lathe so far except for the tailstock.
You can e-mail me if you so choose. Or respond here.
Re: General lathe OT
>Hi Derek,
Disclaimer : I have not turned on the Jet, but I did do a fairly thorough comparison of the two, so I may be a little bias.
It certainly is a good buy considering the lathe that you are getting. I find that this lathe is equal to the Jet in all of the significant aspects of a mini lathe. The overall construction of the General seems to be superior to the Jet. If you can take a look in person and compare the two, you will see quickly the rigidity of the headstock, bed and tailstock in comparison with the Jet. I think the Jet has a total weight of 68 lbs (correct me if I'm wrong) and the General weighs in just over 100.
Alot of people complain about things like the plastic pulley cover, but it in no way effects the performance of the lathe. Also the plastic knob on the toolrest height adjuster is sometimes a nuisance, but it does what it is suppose to. These are relatively minor setbacks which are outweighed greatly by the price difference.
By the way, the set screws in the tailstock handwheel had actually made little gouges in the quill screw...of course I had just been drilling out some holes with a 2 1/2" saw tooth bit and I wasn't exactly taking my time doing it, so that problem with the tailstock was really a fault on my part and not the tailstock itself.
After comparing the two and then purchasing the General, I felt that I had chosen the right one and in fact, got a better lathe for a lower price. I am very satisfied with my purchase and when I upgrade to a larger lathe, it will likely be a General.
Gil Jones
>I have the same lathe, and it is a good machine with a couple small problems. No tailstock troubles here. The setscrews on the motor pulley will come loose often, unless General has modified the pulley like I showed them. It has two, tiny, metric set screws. I removed mine, drilled, and tapped the setscrew holes to take SAE 10-32 set screws, plus I added a third set screw. They do NOT come loose anymore. Here is a pic of my mod.
