Hollow Forms?
Hollow Forms?
Hollow Forms?
tek-Brunswick, Ohio
>I picked up a couple of hollowing tools from John Jordan at the Desert Woodturning Roundup. They are the �" shank, straight and #1 bent hollowing tools. I haven�t really done any hollow forms except for Christmas Ornaments. I practiced with them today. I didn�t manage to produce a hollow form. I cut through the side on the three pieces I was practicing on. I need to get the feel of where the cutting edge is on the bent tool. What shape and size hollow form is good to learn on? I was working through a 1 1/16 � hole. Should I start with a bigger hole until I get a feel for the tools? Thanks for any advice. I didn�t meet as many of you as I would have liked at the Symposium. I need to order a WC hat for things like that.
Tom
Re: Hollow Forms?
Re: Hollow Forms?
Ed Karch
>Start out on on the inside of a couple of bowl forms to get the feel of how they work. Then drill a few holes in the side of a hollow form before hollowing. These port holes will tell you about the wall thickness. Do a few hollows then saw them open and check the inside. By this point you should be a hollowing fool but watch out as it is addictive.
Re: Hollow Forms?
Good advice!
Mike Schwing from Md.
>Great advice Ed. Practice on a bowl first, then a bowl with a rim that closes in a bit, finally try a hollow form. Even though it will be tough to do, take a forstner bit and drill holes into the sides of that thing. It will allow you to see what is happening and understand, plus the shavings will evacuate themselves. The cutting tip should be a little above centerline inside the form, that way if it grabs, it will encounter clear air as it rotates down and have the opportunity to free itself.
Re: Hollow Forms?
Thanks Ed & Mike
tek-Brunswick, Ohio
>I don�t mind committing some wood to practice pieces. I did practice spindles to learn the skew & spindle gouge, so why not practice pieces for hollow forms? I have a decent supply of silver maple to practice on. What size and shape might be a good starting point? I�ll drill the holes in the piece so I can see where my cutting tip is. I was lighting my form from the inside and trying to stop when the light would transmit through the wall. I just wasn�t always sure where my cutter was though. I�ve turned enough bowls, boxes and other items, that I though I�d pick up faster on it than I have. I did use the straight tool for an odd purpose though. I hollowed a 1 �� high miniature Holly goblet with it. It�s a big tool, but the cutter is only 3/16� wide and did a good job on the little goblets bowl. I bought John�s sharpening jig also. It really makes it easy to get a good edge on the cutter.
Re: Hollow Forms?
Re: Hollow Forms?
RK in Milw
>I teach hollow turning at a Woodcraft in Milwaukee. The class totals 6 hours, usually in two sessions of three hours each.
We use a block of cherry 6 inches in diameter and 4 inches thick. The hole diameter we use is 2 inch dia. We use the Sorby Multi-Tip tool which I think would be similar to what you have. I require my students to turn the outside of the vessel so they can get a good feel for the tool while the can see it work. I stress practicing fine finishing cuts.
It helps to drill a hole to final depth with a forstner bit to get close to the final depth of your vessel. Once you start hollowing you will take short arcing cuts which will produce small ridges. These ridges become your road map to tool location. With the lathe stopped, you can locate a ridge by feeling with your fingers and relocate the tool where you need to cut. Pretty soon you can start to visualize where the tool is.
Stop the lathe frequently to clear chips and feel the thickness of the walls. When you get close to final thickness, measure often with a vessel caliper. Tap the outside of the vessel once in a while. A duller sound will tell you where the wood is thicker. In the beginning, concentrate on achieving uniform thickness rather than worrying about how thin you can get the walls. Aim for a wall thickness of 1/4 inch at first.
As others have said, practicing with a bowl at first is another great way to get totally familiar with the action of the tool. Sharpen your bits frequently. You should only have to barely touch the tool to the wood to produce a pretty good shaving.
Slow down and enjoy the process. You'll be up to speed in no time.
Everyone in my class has a respectable hollow vessel by the end of the class. Students struggle with form more than with the hollowing technique itself.
Have fun!
Re: Hollow Forms?
Thanks RK
tek-Brunswick, Ohio
>That sounds like a good plan for starting out. You mention slowing down, which brings a question to mind, how fast do you set your lathe speed when hollowing? Is it about the same, as you would use for cutting with bowl gouges? Or is it different? I�ll post some results when I get some success.
Tom
Re: Hollow Forms?
Re: Thanks RK
RK in Milw
>I recommend about 800 rpm for most work.
Also, do a search here on Acme Sand-O-Matic and you will find a simple sanding gizmo I came up with for sanding the insides of hollow vessels. A search on posts under my name would work also. The sander should be in the next issue (summer) of American Woodturner magazine.
Look in the articles section for an article titled "Sorby Hollowmaster". There are photos there that I posted showing a cutaway of a vessel to illustrate positioning of the cutting bit for different areas of the inside.
Re: Hollow Forms?
Re: Thanks RK
RK in Milw
>I tried the search and it didn't work. I'll dig up the article and repost if anyone is interested.
Re: Hollow Forms?
RK, I found it last night......
Gerald - Southern NJ
>You have to go to the Messages Archives and do the search. The pics were excellent help. Thanks again.
Gerald
Re: Hollow Forms?
Re: RK, I found it last night......
tek-Brunswick, Ohio
>Thanks I found it too. I just bought some velcro hook material, at the DWR symposium, from the Sanding Glove Co. They said Household Goop is the best adhesive for it. I bought some of that from them too. I'll have to try to make one of the Sand-o-matics. Of course I need to make a successful hollow form first.
Thanks
Tom
