Re: Which Sthil or Husky to get?
Mike Schwing from Md.
>You will probably receive LOTS of different answers to this question, and they're all going to have validity. Ultimately the choice will be up to you, but I recommend buying the most saw you can comfortably and safely handle. A large saw can make short work of small stuff, but a small saw can only handle so much, no matter what you do with it. And in the case where you need a chainsaw in an emergency - bigger will be better. Even though you cut moderate sized logs, a bigger saw will do the job more quickly and tire you and your muscles out less, plus make you more likely to actually use your saw if it is not going to be a chore, as I have found underpowered saws to be. My Stihl can reduce what would be a 30 minute job with a small homeowner saw to 10 minutes. This makes me much more likely and eager to get it done.
Now as for what specific size - you don't want to mimic me unless you're as small as me - 5'5", 135lbs. I have a Stihl MS360Pro - a pretty substantial saw, but puny for a guy like Bill Grumbine. The pro version is lighter by about a pound, and I can safely handle it. I would have liked a bigger saw but I just can't safely use one.
Invest in a few different sized bars when you are able - I have a 14", 18", 20", and 25" and 2 chains for each. You will be glad you have the right size bar for each job. If you call Stihl they will tell you what size bars each saw can really handle - which is more bar than is advertised in their literature.
I do not own a Husky, but plenty of folks here do. I would buy my saw over again in a heartbeat, but doubt I'll ever have to do so.
