Power Visor battery
Doug
>I have acquired a Power Visor with the original 4hr battery and charger.
Can someone tell me how long I should leave the battery on the charger?
Thanks,
Doug
Power Visor battery
Doug
Thanks,
Doug
Racal 3M?
T Daniel
>IF so the recommended charging time is 8 hours. The original batteries don't hold a charge very long but they will work fresh off the charger. You can get the batteries rebuilt and upgraded.
Re: Power Visor battery
Fog Tanner
>The batterys that come with the Powervisor are somewhere in the 500-600ma range. A normal charge rate would be 50-60ma or C10. The charger that came with my Powervisor is 170ma which works out roughly to a C3 rate. That will charge the battery in 6-8 hrs, which is OK if the battery has a C1 or C3 rating. If it has a C10 rating the battery will overheat and vent, which will shorten the battery life.
There are other factors like how much of a charge is in the battery when you start. 6-8 hours is for a dischaged battery, if you have only used it for 30 minutes and charge for 8 hours, it is basicly overcharging. There are smart chargers which are the way to go. They will charge the battery up to capacity and then switch to a trickle rate. I have five of them and they are great. For the price of the Powervisor or Trend they should come with one. The Airstream comes with one, but could not be used on the Powervisor (3 cell vs 4 cell).
The best thing is to make a simple charger that will charge at 55ma with a switch that will allow you to put it on a 5-10ma charge after the 16 hr charge cycle. It can be left on trickle with no problem. You can also make up some battery packs very cheaply, they can be a pack with a connector on the end of the wire leads that plug into the helmet. The pack is velcroed on the visor headband and external, plug the hole with a piece of foam and you are good to go.
Fog Tanner reply
Doug
>Thanks Fog for the great info.
This battery pack shows - 3.6 volts / 0.60 amp hrs
Charger shows - output 4.2 VDC / 230ma
I am not sure how these stats relate to the info you gave. I guess I'll just charge it
for 6 to 8 hours and see how it goes. Battery was fully discharged.
Re: Fog Tanner reply
Fog Tanner
>One other piece of info since you said the pack was fully discharged. When you buy a pack or cells they are stored flat, but once you charge them, you don't want to let them go flat. They will self discharge at a daily rate, depending on temp and the cells. Fully charged they will reach 1.32-1.35volts per cell, but this will drop within a few minutes of load to where they will stay for the majority of their duty cycle. This is usually around 1.25 volts. Once they drop below 1.2 volts the curve can get pretty sharp. The key is 1.1 volts per cell or 3.3 on the Powervisor pack. When you measure the voltage you should have a load (around 200ma) on the pack. This will give you a 'real world" reading of the condition of the pack and what it is capable of.
The catch is, you don't want the pack to get that low. Cells can reverse polarity under that. Since the cells in your pack are not matched, even though 3M is charging you matched cell prices and then some, one cell could reverse at a little higher. When this happens, that cell will cause the other cells to "charge" it, no matter how long you leave it on charge it will not go back to normal. All this "stuff" in the instructsions that say to discharge the pack flat are just trying to sell you more over priced packs. All those claims about ni-cads developing memory is true - for batteries 30 years ago. Its not a worry today or for the last 30 years.
I raced model airplanes for 30 years where the batteries were life and death between then plane flying 200mph or hitting the ground at 200+mph. You don't have the same worries, I doubt you can fling your Powervisor against the wall 300 feet per second, but it is a nusience to have your pack die on a Saturday evening and having your lungs blasted with dust coming of the lathe at 44fps. Given care you should be able to get five years out of your pack. That is what I get from the battery packs in my sport planes.
