200+ woodworking book reviews
Nova DVR Static Problem
Kenneth George
>Had a problem last week while buffing some bowls. Buffing has been creating some sizable static charges that discharge when I touch the lathe. Startling but no big deal. I was concerned though as one time the charge discharged when I hit the off button. After this I tried to remember to discharge at another location and had no problems. On Thursday I forgot to discharge before hitting the off button and the lathe turned off. Didn't stay off though, started on its own and I had to switch the main power off. After that it wouldn't start. Called Woodcraft support who forwarded me to Tim Geist who does Teknatool DVR repairs. Tim was very helpful asked me to do some troubleshooting and finally decided that the board in the control box that contains the speaker had taken the hit. He sent me a new one and it arrived on Saturday. Fantastic service, and it solved the problem.
Has anyone else had static issues with a DVR?
Ken
Re: Nova DVR Static Problem
Carole Valentine
>No but thanks for the warning! I do most of my buffing on my Mini, not my DVR and I think I will continue doing it that way! From working on computer componets, I do know that a realtively small static charge (one you can't even feel) will fry various sensitive components.
Did you find it difficult to swap out the boards? Looks like a real job getting that headstock apart to me.
Dave Belser in NH
>I had a very similar thing happen with my DVR when I bought a dust collector. I have a swing arm for the dust hood and plastic hose to the DC. I zapped my DVR when I hit the stop button, after that it wouldn't spin at all. Teknatool service and support was great especially Tim Geist, but I ended up swapping for a new DVR-XP
In the process of trying to figure out what to do I realized that I had bought one of the last DVR's from WoodCraft before they started selling the new DVR XP. So I talked to WoodCraft about there return policy as the lath was only 2 months old - they were happy to exchange the DVR for a DVR-XP plus the price difference. Both lathes are a pleasure to use - but the XP definitely has more torque at low speeds. I've done the 220v conversion (remove jumper change plug).
My shop is in pieces right now as I'm having a perimeter drain installed. When it's done I'm going to move the dust collect farther away from the lathe (man is it loud hanging from the ceiling over the tailstock!) and run metal duct to more machines.
I'm now very careful to touch the lathe head or ways before hitting any control buttons. I might try some metal tape strips on the control pad between the buttons and connected to the headstock case - just to make sure. I should point out that here in NH it's winter which means cold DRY air - my shop humidity is hovering around 20%.
- Dave
Not on a DVR, but on my PM3520
Craig Daymon
>I was sanding the outside of a cherry bowl with 800 grit the other day while standing on a pile of chips. I touched the lathe bed and got one of the biggest static jolts I've ever gotten. Then I did it again, I wasn't finished sanding. I'll be careful not to touch any important controls.
-Craig
Kenneth George
>Carole,
Swapping the board was quite easy. Just 4 screws hold the control box in place. Once loose there were 2 screws holding the board in place and 3 connectors to remove. 2 of these connectors had some kind of hard wax on them, I assume to either hold them in place or to tell if the connectors have been removed. I am hoping its the latter. I'd hate to have those connectors vibrate loose!
Ken
Re: Not on a DVR, but on my PM3520
JKJ in East TN
>I wonder if a light antistatic spray would fix the static problems. This comes in a can at office supply stores. I used it on my chair/rug when my studio was carpeted.
Keith I - East Tn
>We used grounding straps in the military for that very reason. You may find this web-page interesting: http://www.mycableshop.com/PDFs/ANTISTATIC-PERSONAL.pdf
Keith
