Heat for shop
Heat for shop
Heat for shop
Sean Troy
>Hey all, with all the talk of the cold,what seems to be the best and safest method of heating a shop that already exists? Thinking of sanding dust and flames, that's scary !
Re: Heat for shop
Re: Heat for shop
Jim Shaver - Oakville, Ontario
>Hi Sean,
I use a small construction heater($50 at HD a year ago), 4800 watts I believe. I run it for an hour and it is warm enough for me to work out in my shop all day with it going, mostly turning only, I love to do flat work with the garage door open...oh, and no fumes!
Take care,
Jim
Re: Heat for shop
Re: Heat for shop
gil jones
>I use a 2-Ton Carrier Split System Heat Pump that I bought used for $300. Heats and cools the whole shop. Of course, SW Georgia does not get very cold, but it does get mighty warm and humid. R19 walls, and R30 ceilings, and thermopane windows.
Re: Heat for shop
Re: Heat for shop
MFoster
>I live in Vermont and heat my shop with a kerosene heater. The unit I have is a Monitor, but there are a few other similar models. These heaters are very efficient (87%) and the best thing about them is that they pull in outside air for combustion, and vent it right back out. The combustion chamber is sealed so no explosion risks with vapors etc. I installed a 200 gallon tank and plumbed it by gravity feed into the shop. These units can be programmed to your desires. I have mine set for 50 degrees during the night and 68 during the day.
Keep in mind that I live in Vermont, but I heat my 30 x 40 foot shop on one tank fill per heating season. I renovated one floor of a barn, and did take pains to insulate it well and prevent drafts, but I am very happy with how well my little Monitor keeps the shop a pleasure to work in.
Re: Heat for shop
Re: Heat for shop
Ken Grunke from SW WI
>If I were doing a new shop, or at least pouring a new concrete floor, I'd use heat tubes buried in the floor combined with good insulation, of course. Even in a poorly insulated structure, a warm floor does wonders.
The heat source can be anything you can run a heat exchanger through, or a boiler made specifically for the purpose.
Re: Heat for shop
Re: Heat for shop
Jim Pugh, Ohio
>Sean, if you can heat with gas (natural or propane), look into your local AGA (American Gas Assoc) source and check out their gas heaters. I have a wall mounted unit in my shop that vents directly to the outside, uses fresh air from outside, is completely sealed, combustion-wise and can be controlled with a thermostat. I use a constantly running cheap ceiling fan for air circulation.
Re: Heat for shop
Re: Heat for shop *LINK*
Fred Bearman
>My shop is 14 x 23, insulated to R19 in the walls and R30 in the ceiling. I use a small oil-filled radiator with a thermostat and timer that I got at the orange BORG. I set the timer for it to come on at 0600 and turn off at 1400 ( I work my real job afternoons ). Even with the single digit temperatures we have been having here in Michigan this past week, the lowest temperature recorded overnight in the shop has been 52 degrees. It is usually in the 60s by the time I finish breakfast and get out there in the morning, but within the hour of being out there with the flourescent lights on, the temperature is hitting around 70 and I'm taking the sweatshirt off. In actuality, the heater thermostat pretty much turns the heater off by 10, because the shop no longer requires much additional heat. I was amazed how much putting that R30 in the ceiling affected the heating in the shop! (and cooling in the summer, as I have no AC in the shop as yet). No open flames, no sparks, and just vacuum the dust off periodically. I have included a link to a heater very similar to the one I use.
Regards,
Fred Bearman
Port Huron, Michigan
A similar heater to mine
Re: Heat for shop
Re: Heat for shop
Bill Hale
>Sean
I have a brother in law who lives in ND and heats a large quanset ( sp ) hut with a used oil heater. He gets the used oil for nothing at places where they change oil in cars, heavy equipment and trucks. Mid winter -20 he can get it up to 70 deg.
These heaters are forced air so no open fire in the shop.
Bill
Re: Heat for shop
Re: Heat for shop - Infrared Ovehead
Mike Brazeau
>My shop is one bay in a three car garage. I have a Natural Gas fired Infra-Red heater and absolutely love it. Thermostat keeps garage just under 50F and I turn it up to 60F about five minutes before I go out to the shop. Costs about $250-$300 Cdn for the season. Tools are not rusting, no exhaust vapours and no ignition fears for sawdust or organic vapours. Initial cost might be a bit higher, but I would do it again. Heat on shoulders and back feels great too!
Mike
