Do I Need to Upgrade My Chuck?
Ryan Dicker in Renfrew, Ontario
>Hey,
I currently have the Precision Midi Scroll Chuck from Teknatool. I recently picked up some fairly large blanks (considering the 10" swing of my lathe) that are about 6" think. They are quite heavy and I'm contemplating either upgrading my chuck to a Supernova2 or picking up a new set of jaws to replace the 50mm that came with the chuck.
Will the Midi with the 50mm jaws be suffice or do I need to upgrade?
Ryan
Re: Do I Need to Upgrade My Chuck?
Jake Niedling
>Ryan - 50mm tenon on the bowl blank will work. Make sure you use your tail stock center for as much of the process as possible.
>Ryan I looked up all those chucks last night. I don't think you need a new chuck for that lathe. I used the original Nova chuck which is similar to yours for a long time on blanks much bigger than you can turn.
Bill Hale
>Cut the tennon as close to min size as possible. If the jaws are wide open against the tennon they make contact in 8 locations on points only.
Turn the tennon so the jaws are almost closed for a better grip.
Good turning and be safe
Bill in Casa Grande, AZ,
>Well, from the advice I was given, I decided against getting a new chuck, but I did order myself a set of mini cole jaws for finish turning the bottom of bowls.
Thanks Again,
Ryan
