C-c-c-cold shop!
C-c-c-cold shop!
C-c-c-cold shop!
Dale Sherman, Manlius/Pompey, NY
>It's 0�F with a windchill of about -10� right now. My shop just doesn't warm up in this weather, even with the 75,000 Btu furnace cranking. Need more insulation and airsealing, I guess. My lathe bearings make a funny noise when they're this cold. I can handle a shop at 25-30�, cuz then the furnace will take it up to 50 or so reasonably quick.
This is the kind of weather where I stay in and sketch ideas for my next project. How cold does it get before you leave the shop for warmer environs?
Scraping frost from inside of my faceshield,
Dale
Re: C-c-c-cold shop!
Ken Oakley-Sunny St. Cloud, Fla.
>Anything below 60 degrees in my unheated shop keeps me inside the house. It is in the low to mid 40's here this AM but will probably get to 60 by noon. Back to the 80's by Wed. Actually had to scrape frost off windshield early last week.
Mac
>We feel your pain....here in Maine....0 this am
Re: C-c-c-cold shop! - not in OZ
georgetroy
>Central Kansas here. It's 40 now expected to be 72 today and 76 tomorrow.(Golf time) Shop will go down to 45-50 max. When I go out to shop in a few minutes it's 60 and then I have to start turning down the heat. Super insulation help's. The builders did the shell and took it the rest of the way. Propane heat. Shop built in 1987. GT
Sean Troy
>65 degrees. But then, I'm in Arizona. It's a dry cold. LOL
Mike Rubes, Apex, NC
>If the air temp dips down to the mid 30's or so, I can heat the shop with my two portable space heaters ok. Anything colder than that, and I don't even try. Here in central NC, we can get some really warm spells, even in winter, but it's only when it gets cold and stays cold that I have to stay out of the shop. If it is 60 one day and 30 the next, I can get by ok in the shop, but three days of 30's in a row and I'm inside :)
I'm a cold weather kind of guy, but I would rather have the shop too hot than too cold.
Mike
Already looking forward to Spring in Apex, NC
Mac
>OK guys,stop gloating about how warm you are......people from warm areas come back in the next life as brass monkeys and live in Maine...........
David Breth
>That cold shop sounds pretty good to me. Had a long road trip with my family yesterday. My wife was cold so she turned the heat up all the way (fan was on the low setting, but heat was high) and dozed off. I have learned not to alter the temperature setting. I stripped my coat off, unbottoned my shirt down to the belly, and "glowed" profusely. She used my coat as a blanket.
If I say "its hot", that carries no weight, BUT, a few miles from home, thank goodness the 3 year old spoke up. "Why is it so hot?" Mommy turned it down finally. I unloaded the car in 11-degree weather that felt like a window fan in August to me.
Tell me more about that nice, frosty shop.....
David B.
Mine's cozy year round in the basement
Pete in Holland, MI
>Cozy year round, but material/waste movement up & down the stairs still sucks. I'm mostly a winter time woodworker anyway. Play with old tractors when lower Michigan warms up.
Brad Vietje
Depends on the floor
Brad Vietje
>I'm in northen Vermont, and while this has generally been a crazy-warm winter, we do get pretty chilly at times. It was ~ -15F here this AM, and today's high temp will be in the teens above zero -- and windy. As a friend from New Jersey would say: "We know from cold".
I used to turn in an unheated garage with a cement slab. Using an infrared warmer mounted on the ceiling (directed at me), I could work down to about zero (F) for about 3 hours, though I did a brutal 8 hour session last winter getting stuff ready for Christmas that was between -5 and -10. Standing on cold concrete can really make the legs ache ..."we know from warm boots".
When I stand on a wood or dirt floor, these low temps are easier to take. I can turn pretty comfortably in the 30 - 40 degree range (F), with good boots and such, so that's about the minimum heat I'd want to be comfortable, though 50 - 60 would be even better. I certainly wouldn't want it real warm, as green wood tends to split a lot more when in a dry, hot environment. Conversely, you can work a little slower and get away with a lot more when wood is cold, and avoid some of the checking from evaporation.
When it's real cold, I find that doing finish turning, or turning dry wood works well, as turning dry wood generates more friction and heat, and the tools warm up after a few minutes. Rough turning green (frozen solid) wood will shorten the turning session pretty dramatically in colder temps -- I don't wear gloves while turning.
Safe Spinning,
Brad Vietje
Newbury, VT
Heavy rain here, nowhere near as cold as U.
Eddie Pacheco; San Jose, Ca.
>My garage shop is insulated and sheetocked and I added foam insulation to the ceiling. I have also added 4 double insulated type skylites. However, my house furnace and 75 gal. water heater are also in the garage and they help keep the place from dropping below 55. These two heat sources also make me try to keep a clean shop.
I was in Denver 2 weeks ago and finally felt what -3 F is like. I was not a happy camper on just a quick dash from a resturant to the car.
More c-c-c-cold shop
Dale Sherman - Pompey, NY
>Well, you sure don't want to touch any metal in the shop with wet hands, you'll be stuck there until the Spring thaw. The fluorescent lights don't work until it warms up. At least the squirrels and mice are quiet when it's this cold, they're snuggled in upstairs in the barn someplace.
My wife is tired of working around the boxes of glue and latex-based materials that I bring into the house. I probably should build an insulated heat box in the shop just to keep the peace in the house.
My car has the flat spots frozen into the tires until I get a mile or so down the road. At least the snowshoveling is light when it's this cold.
Dale
Re: My shop is outdoors...
Paul in Phoenix, AZ
>...so I have real good air conditioning in the winter and great heat in the summer. Actually it's open air on two sides with a cover on top. I can't turn when it raining (if it ever rains here again) and I don't have to worry about snow. In the summer I have an evap cooler blowing on me and in the winter (all 3 days) I wear a insulated flannel shirt.
I just set the thermostat...
Brian Hahn in SW Wisconsin
>I just adjust the thermostat a couple of hours before I go out to the shop and everything is comfy. The trip from the house to the shop (about 140 feet) can be envigorating at times. It helps to have 6" of insulation in the walls and 12" in the ceiling. Wood floors are also real nice. So is central air conditioning in the summer.
Don Tewell
>I feel real lucky. I built a new 2 car garage a couple of years ago and added a 14' extention on the back for my shop. Insulated all wall and ceiling, drywalled and installed a small gas space heater. Set at the lowest setting keeps it at 60 degrees and I usually have to get rid of the heavy shirt when I'm working. Just gets too hot.
Skip Beardsley
>There is a cute postcard sold here which says Montanians feel it is a heat wave at 65 degrees and just cooling off at 20 below. I have a propane(Empire) through the wall heater and am comfortable all the time. Closed combustion chamber so don't worry about dust. Must admit I don't spray lacquer much during the winter. Shop has R23 walls and R 50 ceiling. That is the answer to most problems.
Re: More c-c-c-cold shop
Jorge Castaneda
>Dale,
Right now the tv said it is -30F with the wind chill here in this island. I did turn a little today, made a turning tool handle without much trouble other than the miserably cold hands, but when I did sand the handle, something unusual happened, the sanding dust did not fly around, it was so staticky that it was very cohesive it all fell on the ways like the metal was pulling it.
Tomorrow it will be warmer I hope
Jorge
