camera question
camera question
Keith Tompkins
camera question
Keith Tompkins
>Lots of trouble with my digital camera....Canon A75. I have been experimenting with the settings, and discovered I can get a much clearer image on the "S" resolution setting, or the M1 setting. If I review the images I shoot, I can zoom in and the image remains clear.
In the M2 or "L" setting, which should be the highest resolution, the image is out of focus, and if I zoom in while reviewing, the image is absolutely terrible. I am using the macro mode, ISO is set at 50, with a tripod to eliminate any camera shake.
Any ideas? Any suggestions would be greatly appreciated, as this camera is not long for this world, I'm afraid.
Re: camera question
Re: camera question
Stephen Mushinski
>Hello Keith,
First off - Macro mode should only be used if you are closer than 1.5 feet (18inches) from the object
It is best to be back further and use the built in "optical" zoom to fill the frame. The picture mode for storage you are using is fine. I would not use the viewfinder to tell if it is in focus or not. If you are close to a tv use the patch cables to view your setup real time. You can push the shutter button half way down and it will auto focus for you and you can see the what the result would be on a big screen.
Now about the mode you might want to use aperture priority with it set to the max. which I think is F8.0. Then the camera will figure for you how long to open for the amount of light you have. This will help with the depth of field and hopefully more of the object will be in focus. Tripod is a must for this as the time might be 1/2 a sec or more.
Another item is pick the middle of the object depth wize as the point in the middle of the cross hair press the shutter button half way down holding it, then reposition the object to the middle of the frame before pushing the shutter button the rest of the way. This way the camera will make all of its calculation on where you want it to and not just the middle of the frame.
MOST Important !!! - Make sure you have your camera set for 1-point focus (fixed to centre) and not 9-point. This might be the biggest trouble you are having! 9-point is great for some stuff but for taking pictures of objects and people it is best to use the 1-point.
Note I am not a expert I am just trying to help!
Re: camera question
Re: camera question
>I'm not familiar with that camera at all and Stephen gave some excellent advice. The image quality has nothing to do with focus which is what the problem appeared to be on the goblet. Often in macro mode the distance from subject to camera is severally limited. You may need to move the camera back and forth to find the area that it will allow you to focus correctly. Zooming sometimes will also affect focus. For example, it might focus at 18" in wide angle mode and in telephoto mode won't get closer than 28", or vice/versa depending on the optics design.
I'm a proponent of manual focusing rather than auto focusing but I realize that a lot of cameras either don't have that option or the image in the viewfinder is so poor that manual focusing is impossible. Our early Nikon digitals had this problem.
The Focus lock that Stephen mentioned is the best option. Sometimes putting the image on the TV will tell you whether it's in focus or not, then it's trial and error playing with the auto focus and/or moving the camera a little to see if you can find the area wear the camera will successfully focus.
Re: camera question
ebd
Re: camera question
ebd
>DON'T use zoom in macro mode.
Re: camera question
Re: camera question
eaglesc
>Youu did not say what size the article was that you are trying to photograph.
I take pictured of the pens I make and need close ups with clarity.
I have found the "flower" mode is best(close up) but that ddoes not mean that I can take a picture one inch away from the article I am concentrating on such as a detail on a fitting.
I am sure my camera is not as sophisticaed as yours but it takes picures with excellent clarity.
Kodak dx3600. I t is a 2 meg camera.
I found it took experimentation with a lot of trial and error.If I got a new camera I am sure I would have to start all over again or the same if I was to start turning larger objects such as bowls.
I use no editing software,Natural light when possible.If I am taking a lot of shots I use the video out for focus and framing, windows image resizer from power toys.
I have found cropping and pasting along with lighting/color editing gives the final picture an "artifical appearance"
Try taking a dozen or more pictures on teh same article and make notes of the settings y ou use, that is the only way I was able to "learn" how to get the pictures I am after.
Re: camera question
1-Point/9-Point?
Jennifer@Indy.USA
>Stephen,
I'm not familiar with these settings? What are these referring too?
I have a Cannon Power Shot S330.
Thanks,
Jennifer
Re: camera question
Re: 1-Point/9-Point?
>Jennifer Some cameras have more than one area that the autofocus "sees" to decide where to focus. On some cameras you can manually select which area is used for focus. This is very handy when you are taking a photo of 2 people. The center focus point will focus on the wall behind them so I often us what is called focus lock. this allows you to put the center point on one persons face, push the shutter button down until it focus's on that point and then reframe the image and push the button the rest of the way down to take the actual photo.
My cameras at work have multiple sensors and the camera will try to use a sensor other than the middle one to select the proper focus in the situation above. It still doesn't work all that well so I will manually select the proper sensor, or just manually focus.
Re: camera question
Brad Vietje
Anybody miss those all-manual 35mm cameras ?
Brad Vietje
>I do miss the manual control 35mm days -- once you mastered the how's and why's of aperture, f-stop ratios (and what they actually mean), depth of field, and good lighting, you were SET. On the digital cameras I have used, I'm never sure exactly what is happening with synthetic apertures, binning pixels, and faking the ISO/DIN. The entire format seems less intuitive to me. Since I have some background in optical work, the SLR world made real sense to me. If I could afford the high-end digital SLR cameras with interchangeable lenses and a manual (read: physical) diaphram, at least some of my understanding would translate.
I'm interested in Keith's ultimate, embedded question, which I take to be: "What camera should I get when this thing will no longer meet my needs ?"
Safe Spinning,
Brad Vietje
Newbury, VT
Re: camera question
Re: Anybody miss those all-manual 35mm cameras ?
JKJ in East TN
>Brad,
That's the reason I chose the Olympus E-10 a few years back. It's been an excellent camera, SLR, and all the manual controls like a real focusing ring and zoom rings plus a good SLR weight and balance. It also has fully auto exposure with aperture or shutter priority and choice of auto or manual focus. It also has the cool digital things - white balance control, focus and exposure locks, dual media, IR remote control, etc. The lens is not interchangable, but the zoom lens that comes with it is decent and has a good macro mode and I have addon very-wide angle, ultra macro, and fisheye add-on lenses. With the lithium ion battery base, I can take hundreds of photos on a charge.
I'm not necessarily recommending people consider this particular model of camera since it is a few years old and I think only available used, but there may be others with similar SLR manual feel and features.
After using the E-10, I can hardly stand to take a picture with one of those little PHD cameras!
Re: camera question
RussFairfield
>Brad,
If you like the old manual SLR cameras, you would love the 50 year old Exacta that I still use for 35mm photos. It doesn't even have a built-ib light meter. It doesn't get more manual that that. I have never upgraded because those old Schneider lens are still better than anything available on the market today, regardless of price. It also has some features that have never been available on another camera. It's only fault is a mirror mechanism that could turn over a Volkswagen. That makes a very sturdy tripod a requirement for slow shutter speeds.
Now if someone would make a digital body that will use these lens, my camera selection would be simple.
Re: camera question
>Damn straight I do. I don't necessarily miss film for what I am doing with the images nowdays but even my $300 nikons focused so much easier and I think worked just as well as my $5000 Nikon D2. They have changed all the lenses so you don't ever know where the focusing ring is. Some have them way out on the ends of the barrel so manual focusing is slow and cubersome compared to all of my 20 year old lenses. Sorry folks but auto focus just isn't there yet. It works better than me in some situations but I get an awful lot of out of focus images and have to stop and put it in manual.
When I'm in program mode I never know what it's doing. I would rather use Aperture priority, shutter priority or manual so I have some control over the camera.
The only thing I do like about digital is not having to carry all those filters. We shoot in a lot of different lighting situations here at school and being able to just dial in the White balance is really nice. Made shooting low light theater stuff a real pleasure.
Re: camera question
Re: camera question
Ken Grunke from SW WI
>Keith, my old Canon G2 has four resolution settings probably like yours--L, M1, M2, and S. It also has just below that three compression settings, which at first confused me--one is S within a quarter-circle icon, next is just the quarter-circle with no letter, and third is a stairstep-shaped block. I originally thought S would give the smallest file size, but turns out to be opposite. It designates smallest compression, co-relating to highest quality. Possibly you are misled as I was?
Re: camera question
>I still have my old Pentax MX, but never use it. I'm glad to be rid of the hassle of film and waiting for processing, or developing it myself which I did a lot of in my younger days (black and white only).
If there was such a thing as a digital back to attach to my Pentax that was affordable, I'd jump right on it. There may be, I just haven't looked.
Re: camera question
Ric Taylor
Best I Ever Had
Ric Taylor
>The best camera I ever had was a Minolta SRT 100 back in 1971. Just look through the viewfinder, match one needle on top of the other, and shoot. Great photos. But then one day the beach got smaller, and the ocean got bigger........
Ric
Re: camera question
Re: camera question - Hijack
Mark Kauder, Phenix City, AL
>Anyone want to recommend or warn me away from Digital Cameras in the $400-600 range?
I personally hate the cameras that are about as big as a cigarette pack (remember those?). I like what little I have seen in the Canon Powershots.
Mark
Re: camera question
Phil Joines Krum,Tx
>When I want a GOOD pic or slides for a show it's the old Pentax K1000. There's still plenty of good used bodies and a ton of accessories available.
Re: camera question
RussFairfield
>Ken,
The new Pentax digital will accept all of the MX lenses. The only ptoblem is that they will be manual mode only.
Re: camera question
Jim Shaver - Oakville, Ontario
>Hi Brad,
While I do miss the fun of my 35mm's (two Nikon F#HP's and an Olympus OM-2), what I want to get back to is my 4x5 Linhof Technica IV, now that's fun!!
I hear I scan negs now and print them, so much for the wet darkroom I was building!
take care,
Jim
Re: camera question
Keith Tompkins
Re: camera question
Keith Tompkins
>Thanks for all the replys....I'll keep trying. When I zoom in instead of using the macro setting, the results are worse. Spent all day at Barnes and Noble reading about digital cameras...
I'll let you know if I'm successful...btw, love my old Pentax K1000
Re: camera question
tek-Brunswick, Ohio
>Mark.
Could we have a little more information on what you want to do with the camera? It will help with giving advice. I have the Canon PowerShot A610 and love it. It is larger than the cigarette pack size cameras and smaller than the Digital SLR's. I think Sean Troy has the A620 and is happy with it. It's basically the same camera except it has 7 Mega Pixel resolution and the A610 has 5 Mega Pixel resolution. The A610 is about $90 less than the A620. I like the fact that I can use the camera in one of the preset modes for getting off quick shots and it does pretty good focusing in low light situations. I just took close to 300 shots on vacation and most of them came out good. I can throw out 3/4s of them and keep the really good ones. That would be expensive to do with a film camera. If you want to get technical in shooting your work you can use shutter priority, aperture priority, or manual modes. I think the automatic white balance usually does a pretty good job, but you can also custom set the white balance. On the whole the digital cameras are much improved over what they were a couple of years ago. My daughter is an Art major at Kent State University. They still encourage taking slides of their work for their portfolios. The Art world believes slides are superior to digital photographs. I think all juried Art Shows accept slides of work Artists want in the show, some juried Art shows also accept digital photos of work Artists want to submit, and some do not. She is using my old Olympus OM1n for slides. It takes great slides. It is a manual SLR camera and I�m too slow with it to use it for snap shots. I also have an old Argus range finder Camera that is manual and takes great slides. I think it is an Argus C4. I like the digital cameras though and have no desire to return to film for my primary camera. I hope I�ve been of some help I�ve had good service and prices buying online from B & H Photo. Some one else on WC had good luck with Beach Photo if I remember correctly.
Tom
Re: camera question
>Jim I sold my 4x5 Wista and my 8x10 Kodak last year. I miss them both but I just wasn't using them anymore and film was getting really expensive especially for the 8x10.
Re: camera question
>Mark Look at the Panasonic Lumix models. I think they are around there and have a lot of good features.
Re: camera question
A610 Picture
tek-Brunswick, Ohio
>Here is a vacation picture from The Desert Woodturning Roundup. We stayed another week in AZ, so I'm just posting now. For those of you who are not familiar with him, this is Kip Christiansen. I watched all 4 of his demos on Saturday and I wasn't disappointed. I really enjoyed the symposium.. This was taken under fairly tough conditions. I had to zoom in from farther back than is recommended for the flash and had to partially depend on existing light. I had no tripod with me so the camera was hand held. I only took a couple of pictures at the symposium. I should have taken more.
Tom
Re: camera question
mark4583
>Still use them, only non manual I have is the Nikon 90s
rest are MF, Mamiya RB 67 pro sd II, mamiya RZ, Blad 501 and 503 and a old Bronica S2, even with the 90s I use in manual mode 90% of the time.
Re: camera question
JKJ in East TN
>>...so much for the wet darkroom I was building!
I finally sold my entire darkroom last year with an Omega D2, but kept the 4x5 camera just because. Like others, I miss the cameras but do not miss the chemicals and dealing with the film. I did love the magic of watching the image appear on paper but man, digital is so, so much quicker and easier.
BTW, I bought a Nikon film scanner to access a bunch of old slides was surprised at how well it handles slides and negatives.
