Future shop - ready to start on the building part
>I have been woefully behind on my shop time due to the amount of time spent on getting the new house in shape. Every room and all the closets are now painted. The shop part is now painted and I'm ready to start putting up walls. I am currently planning on using some sort of 1/2" wood paneling for the walls that I put in (any suggestions?) and leaving the rest as painted cinderblock. Here is a view of part of the shop.
Re: Future shop - ready to start on the building part
Re: Another view
>Yes, the floor is a shade of green. I got tired of gray.
Rick Davenport
>Look at all that square footage!
I'm speechless and flabbergasted.
Agog and aghast.
In shock and awe.
You lucky so and so.
Too many options for me.
I'm trying to assimilate the possibilities.
It's too much.
You're on your own.
Enviously,
Rick
Jerry Whitaker
>Keep this picture.....it is cleaner than it will ever be again!!!
>Rick - a poetic tribute even - I am agog at your poetic talents :). In terms of square footage, it's maybe 450 sq. ft. or so. It'll be crowded soon enough.
shop walls
JKJ in East TN
>Hey, all you need now is about 35 electrical outlets! Is this the 1/2 basement area of which you posted a diagram earlier? I'll bet you can't wait to get it done. (I think I can start on my new shop this spring.)
I really like the idea of wood walls for hanging things. If put over treated 2x2s there would be enough space behind for wiring without eating too much into the room area. I hope to use similar walls on my shop, light colored paint, and put up with screws so the panels can be removed for access if necessary.
Maybe next time I get to Atlanta I can bring some wood for a shop-warming present.
Re: shop walls
>John,
I am going to leave the cinderblock walls as is. I figure I can run conduit down the walls pretty easily. The interior walls are the wall that I have to build. I am mulling over various products to sheath these walls. I don't want drywall. I was thinking of either plywood of some variety or maybe even an exterior siding.
ben d.
>When I built my shop I used 1/2" mdf on the bottom 4' of the wall and then used 1/4" peg board to the celing. I can hang anything where I want to or if I want to nail a board up to hang something to I can do that too.
Works well for me.
Carole Valentine
>What are you going to do about outlets...run the wires through conduit on the cinderblock? Can't have too many outlets in a shop!
>Yes, I am going to run conduit down the cinderblock to a variety of outlets. I am currently planning on running three outlets for 220 V on the side cinderblock wall and a single 220 V outlet on the wall that I am putting in. I will probably run several 110 V outlets on each wall also.
Brad Vietje
Good God, that's WAY too nice to be a shop !
Brad Vietje
>OK -- you're in for it now. I really gotta get off my kiester and get a new camera. Just wait till you see the ugly old barn that will house my new shop... While I'm building a pretty respectable office in that barn, the shop space will probably be some strapping and tarps to contain the dust and mess through the fall. Eventually I'll have windows, walls, a floor, and everything -- even a door !
I can guarantee it won't be so pretty as yours -- you win !
Maybe you should cobble together an ugly but functional shop (so some of us won't feel so bad), and turn that room into your retail gallery !
Safe Spinning,
Brad Vietje
Newbury, VT
Re: Good God, that's WAY too nice to be a shop !
>What - because I painted the floor with a "custom" color ("Appalachian Trail" - Benjamin Moore floor and patio paint) and painted my walls? What are you going to say when I put in the suspended ceiling?
Power outlets
Brian Hahn in SW Wisconsin
>My 110 power outlets are double duplex outlets (4 outlets total) and the two duplexes are on separate circuits. That way I can plug two heavy-draw items into the same outlet cluster, one into each duplex, and I don't have to worry about overloading the circuit. (I effectively have 220 in each box, but wired and used as two independent 110 circuits.)
Re: Good idea! Thanks.
Bill Hale
>Several things you may want to consider.
Use the shop for a while and find out where you actually want things and then do the electrical. Be sure to use heavy ext. cords until then.
Do a sub panel in the shop and do circuits from there.
Consider some duplexes in the ceiling, they are handy.
Shop vac system location. Pipes in the rafters with drop downs where needed. I use 4" black sewer pipe for the runs. You can glue in the blast gates. Install sideways.
Air lines in the ceiling with drop downs. I use 3/4 Sch 40 PVC pipe. I use 4 x 4 block to hold the quick conect off the wall. This makes the airline plug in easier.
Last do the lighting. Home Depot has some 8 ft fixtures that hold 4 T8 bulbs. Very bright. Do not get 8 ft tubes because the balasts hummmm. I would leave the ceiling open for acess.
Bill in Casa Grande AZ.
>"Use the shop for a while and find out where you actually want things and then do the electrical. Be sure to use heavy ext. cords until then." - I obviously haven't used it, but I have planned where I want the equipment. I have to have the electrical roughed in for the inspection, so after I get the studs up, I'll put in the electrical for the inspection.
"Do a sub panel in the shop and do circuits from there." - Subpanel is going in near the corner.
"Consider some duplexes in the ceiling, they are handy." - Point taken, I'll plan on it when I do the overhead circuits. Thanks.
"Shop vac system location. Pipes in the rafters with drop downs where needed. I use 4" black sewer pipe for the runs. You can glue in the blast gates. Install sideways." - I am going to be using 6" pipe per Bill Pentz' site. I may be using 6" metal.
"Air lines in the ceiling with drop downs. I use 3/4 Sch 40 PVC pipe. I use 4 x 4 block to hold the quick conect off the wall. This makes the airline plug in easier." - I don't have a compressor. I may get one, but I can easily run a line along the ceiling. I may end up running a line up along one or more of the joists.
"Last do the lighting. Home Depot has some 8 ft fixtures that hold 4 T8 bulbs. Very bright. Do not get 8 ft tubes because the balasts hummmm. I would leave the ceiling open for access." - This is a basement. I am going to put up insulation between the joists. I am going to be doing 2'x2' ceiling grid with 6 2'x2' light fixtures for overall lighting. Task light will be track lighting over the tablesaw, the lathe and the work bench.
Thanks for your opinion.
Dennis Y
>Use copper for air lines much safer. PVC can burst with major shards that will do more damage than an errant piece of wood off the lathe.
Brad Vietje
Brad Vietje
>No -- because you have a floor -- a painted floor -- and painted walls, too !
'Course I'm just pokin' fun here -- a left-handed compliment -- green with envy. I'm just imagining a shop with nice white walls, a painted floor, and HEAT ! I'll get there someday soon, but mine still won't look that nice.
BTW: I looked into suspended ceilings for my office/future shop, and found very little that didn't have a perforated surface, which I figured would trap a lot of dust and grit despite my best intentions with dust collection. (there is a washable white surface in 2' x 4' suspended panels, but I went for tiles) I ended up installing a washable smooth surface ceiling tile that staples to furring strips nailed to the ceiling joists. It might never be a shop, as I might keep it set up as an office, with a photo booth and a weekend gallery. I'll probably include a work table for carving, woodburning, and maybe dust-free finishing, but we'll see.
I think my eventual shop (this summer or fall) will be an enclosure on the other side of the barn with a cement slab with solar and wood powered radiant heat floor. Design pending...
Safe Spinning,
Brad Vietje
Newbury, VT
