Cut some blanks with JKJ yesterday
Dick Parr
>I had the pleasure of going over to JKJ's place yesterday morning and spending some time with John and his WoodMizer. I took a truck load of cut up logs over and we turned them into turning blanks.
The WoodMizer made short work of cutting the blanks. It made it a lot easier then using a chainsaw.
Thanks again John for the help and the good time.
Dick
Re: Cut some blanks with JKJ yesterday
Dick Parr
>Here is John using the mill
Dick Parr
>And me getting my first lesson on the WoodMizer
georgetroy
>Thanks for showing Dick. That wood Mizer and 2 trucks cost a lot more than all 6 of my lathes. Good turning. You posted some of your finished product from this load. GT
Gary Evans Tallassee, TN
>Hi Dick,
That's not John, that's some old guy! 8^]
Sorry I couldn't get over there.
Gary
Dick Hines
Dick Hines
>Looks like you will be keeping the old lathe warmed up for a while.
Good clean fun!
JKJ in East TN
>You'll have enough wood to turn all week now! I want to see some turnings from those spalted pieces. Too bad we ran out of time before getting to some of that walnut on the flatbed in the background.
We learned a lot about cutting small chunks.
The fixture to hold the sections was simply a couple of 8/4 boards fastened into a strong L shape. I cut the fence into a high section and a low section. We clamped a chunk against the high fence with the log clamps, skimmed the top surface flat, and cut out blanks and pith until we hit the fence. Then slid the fixture to the low part of the fence, flipped the remainders, then skimmed the other side and finsished up. When I get time, I want to try making a heavy "workbench top" to set on the bed with holes bored for dogs and clamps. I think this will let me hold a wider variety of shapes securely. You do NOT want to cut into something that is not securely clamped and might move or roll even a little bit - that would be like cutting into an unsupported round or block on a vertical bandsaw. Could get exciting with 15 hp pulling the blade.
Jim Shaver - Oakville, Ontario
>Hi Dick,
Looks like an awesome time....John really knows how to slice and dice eh!!
Take care,
Jim
Dick Parr
>We missed ya Gary, there was something said about how you had to Work on Saturday. That's a heck of a way of getting out of some fun.
Hope we can all get together next time because it was a fun day.
Dick
Dick Parr
>You are right Jim, John is a really great host when he has you over to have fun.
